Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 09-05-2005, 08:44 PM
Batznight Batznight is offline
Question Installing Amp
Hi all I got a Concorde '99 or '00 don't know, well i was installing the amp and when i needed to put the power cable from the trunk to the batery, but i can't find a hole to put it from the there to the engine, can anyone help me plz, thats all i need to know, ty.
Old 09-06-2005, 08:49 PM
Bizzy102 Bizzy102 is offline
Re: Installing Amp
You Gotta Make One If You Don't See Any
Old 09-06-2005, 08:50 PM
ok thx
Old 09-30-2005, 07:24 AM
blackdragon258 blackdragon258 is offline
Send a message via AIM to blackdragon258 Send a message via MSN to blackdragon258 Send a message via Yahoo to blackdragon258
Re: Installing Amp
If I remember right, I ran mine along with a brake line or the power steering. Either way, you need to run it through an existing hole in the firewall. No easy way to do it.
Old 09-30-2005, 09:03 AM
Yeah I installed it, thx people, I did what blackdragon said, I found a existing hole in the firewall where the brakes are. Thx.
Old 12-08-2005, 05:38 PM
JustinGoodie JustinGoodie is offline
Re: Installing Amp
I've gotta run 4 gauge and i was looking for a hole to run it through... i saw the hole you're talking about, but i couldn't find the other side of it... is it very accessible?? i pushed a screwdriver through there but i couldn't see it coming through the other side, and as far as i can tell, it's gotta exit underneath the master cylinder.
maybe i'm just getting frustrated, but i can't tell where that hole goes
Old 02-12-2006, 05:43 AM
passwarrenty passwarrenty is offline
Re: Installing Amp
run your cable from the engine compartment to passenger door there is a small opening that it can fit by the door hinge there is a rubber plug that get you in the car then run it under your door trim inside when you get to the back sit run it to the trunk did it on my 02 concorde
Old 03-13-2006, 12:48 AM
nktidwel nktidwel is offline
Re: Installing Amp
The hole come out behind the plastic in the wheel well. Just did mine yesterday.
