Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 09-05-2005, 05:56 PM
armagh armagh is offline
2001 breaks
I am having a problem taking the bottom bolt out to replace the front brakes on my silhouette. if I am facing the wheel hub do i turn the bolt towards the rear or front of the van to remove it
Old 09-12-2005, 03:16 PM
94 Jimmy 94 Jimmy is offline
Re: 2001 breaks
Yes, (the wise ass answer).
It all depends on which side of the van your on. The old saying goes ...righty - tighty, lefty - loosy. That's from the head of the bolt looking down the shaft.
As I remember it these calipers are held on with a Torx or Allen head bolt recessed in a rubber cup. Why don't you get the Haynes manual at the place you got your pads, it's about $20 and well worth it. It will lead you through about everything you should do to your van, including brakes.
Good luck
94
