Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 09-05-2005, 06:42 PM
paul52 paul52 is offline
Angry 1997 Jimmy blowing transmission fluid out!
Transmission fluid blows out the breather. Shifts EXTREMELY hard from 1st to 2nd gear. The tires actually squeal it is that hard shifting. Had trans. rebuilt and still have the same problem. SOMEBODY out there has had to have had a simialar problem. This is driving me nuts! Help!!!!!!
Old 09-09-2005, 11:19 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1997 Jimmy blowing transmission fluid out!
Take it back to the tranny shop.
You paid them to fix it, now have them fix it again.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-30-2005, 12:22 PM
Jimmy58's Avatar
Jimmy58 Jimmy58 is offline
Tranny problems
Have your tranny guy check the accumulator spring under the valve body. If it is broken your tranny will shift super hard and bypassing fluild will over heat and boil over. Just my 2 pennies on this topic
Old 11-23-2005, 01:21 PM
dustyr dustyr is offline
Question Transmission fluid blowing out when hot
I have the same problem. It started after we changed the Radiator, worked fine until then, now it got all kinds of probs, one being fluid coming out of dipstick when it gets hot - makes it look like your on fire - wife panics! Got to find a solution. Did you get yours fixed?
Old 11-24-2005, 01:01 PM
GT11 GT11 is offline
On my Jimmy I have three cores in one radiator. One core cools the water/antifreeze, one cools the engine oil and one cools the transmission fluid. Could be one of the cores in the radiator might have a hole in it causing fluids to mix. Just my 2 cents. Hope this can help...
GT
