Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 09-05-2005, 05:16 PM
toicy4ya's Avatar
toicy4ya toicy4ya is offline
How To Change Automatic Transmission fluid and Filter??
Sup guys,
I did a search on this but came up with mixed results. Being that its my first time I want to make sure I get it right. I recently drained some trans fluid and noticed some kind of grany substance which prompted me to want to change the fluid. Can someone give me some precise instructions on how to change the trans fluid on a "AUTOMATIC 2.4 ENGINE", also is it necessary to change the filter? Does anyone have a link with possible diagrams on how to do this? Can I use GM/Penzoil Synchromesh fluid on a auto transmission?
btw, is it normal to have those grany material in the trans fluid?
Thanks
99 Eclipse Spyder GS
Old 09-05-2005, 05:52 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: How To Change Automatic Transmission fluid and Filter??
no, you don't HAVE to change the filter, but it can't hurt and is a no-brainer if you plan on taking the pan out. There are several different ways to change the fluid, and if you plan on changing the filter, the best way is to just drop the pan off, empty and clean it, change the filter, fill the pan with a little fluid, bolt it back on, and fill it the rest of the way with the fill tube.
No, you cannot use that fluid, you must use the fluid listed in your owners manual or one listed as being compatible to it.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 09-05-2005, 06:20 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
If you have the drain plug thing, use it. I had to change the fluid and filter on a car without a drain plug and it was a pretty big mess. I think its ok to have the grainy shit in there, all of the tranny pans I have seen have had some in it.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 09-05-2005, 07:08 PM
Killa's Avatar
Killa Killa is offline
go to misubishi dealer and buy auto tranny fluid ( it the best for our car ). By the way only fill up with 4 r 5 qt , first time I do it I fill up with 9 quart and almost F*CK up my tranny. good luck man .
Old 09-06-2005, 12:06 PM
toicy4ya's Avatar
Thanks guys,
I love the fact that I can rely on you guys.
What are your takes or feedback on Tranmissions flushes? I have asked several people about this and some have said that its good yet others have said that their transmissions have acted up after they performed the flush.
Old 09-07-2005, 05:07 PM
drdisque's Avatar
powerflushes are the devil in the mechanical flesh
gravity (fill, drain, fill) flushes are good.
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
Old 07-30-2006, 06:10 PM
H_Chase H_Chase is offline
i have a 96 ford explorer sport 4wd i was coming home the other day and when i put it into gear i had to floor it so that it would catch so i was told to try and change out my transmission filter. i've taken the pan off ond the fluid smells burnt what could be the cause of that and also my overdrive light is blinking off and on
Old 07-30-2006, 10:29 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-30-2006, 11:15 PM
AbsoluteGTR's Avatar
AbsoluteGTR AbsoluteGTR is offline
Send a message via AIM to AbsoluteGTR Send a message via MSN to AbsoluteGTR
First off, do a search and post in the right section of AF...you missed the ford link by alot
But if your overdrive is blinking on and off...then you have a more serious problem...SEARCH
Old 07-31-2006, 01:48 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
And this thread is almost a year old, next time watch the date.
95 Talon TSI AWD
97 Eclipse GST
Old 07-31-2006, 02:11 AM
Thor06's Avatar
Jizzed In My Pants
Closed Thread
