Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 09-05-2005, 02:06 PM
bmw2002nut bmw2002nut is offline
fuel pump secondary circuit??
Ive got 4 codes on my 99 Passat 1.8 as follows:
P1237 Fule pump secondary circuit malfunction OR vacuum switching valve 2 circuit malfunction
P1238 Vacuum switching valve 3 circuit malfunction
P1239 Manufaturer specific powertrain touble code
P1240 sensor power supply malfunction
Seems to me that they are all related since the codes are in sequence and seem to be related to the fuel system. hopfully one fix will cure them all but im not sure where to start. Anyone have any suggestions or more info that might help??? It would be much appreciated!!!!
Old 09-05-2005, 05:59 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Is you battery voltage low?
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 09-05-2005, 11:31 PM
battery voltage should be ok. Its a fairly new battery and it sounds fine starting. Ill give it a test to make sure though.
