Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-05-2005, 01:43 PM
peachy420 peachy420 is offline
key stuck in ignition 95 saturn dohc
my key is stuck in the ignition, most people told me that this is usually due to the ignition switch needing to be replaced, but i think it could be something else, because it happened right after my battery died, so i want to know if there is maybe a switch or solenoid? thanks!
Old 09-06-2005, 01:00 PM
peppermrj's Avatar
peppermrj peppermrj is offline
Re: key stuck in ignition 95 saturn dohc
Welcome to the forum.
No. Not that I'm aware of.I know when i first got my 96 I always had trouble with the key. It was only due to getting used to it tho. I think you have to push it in to get it all the way over to the off position or else it won't come out. Also try turning the wheel a little either way to remove it. In park yes?
Old 09-06-2005, 02:27 PM
tried that a long time ago didnt work, found out that it was the shift interlock!
Old 09-06-2005, 05:30 PM
peppermrj's Avatar
Re: Re: key stuck in ignition 95 saturn dohc
Thanxs 4 the update.
