Go Back   Automotive Forums Car Chat > Buick > Regal
Old 09-05-2005, 12:04 PM
caddyman379 caddyman379 is offline
How the hell do i get to the rear spark plugs
hmm, okay, i decided to stick with the engine i have.
i replaced the three front spark p[lugs, and battery.
the engine starts hard, and wont stay running for too long. the smell of gas is strong, and there are no fuel leaks.. when i changed the front three they looked pretty old, so i figure changing the back ones wouldn't hurt, as it seems fuel is going unburned.
Someone want to give me a step-by-step on removal of the rear plugs?
Old 09-05-2005, 02:24 PM
tman's Avatar
tman tman is offline
Pimpin' ain't easy
Send a message via AIM to tman
Re: How the hell do i get to the rear spark plugs
you're gonna need a lot of patience, and probably a 6 pack to get you through this.
The rear plugs are horrendous to get to. I'd suggest getting some vice grips, and latching them onto the spark plug wire, and twisting and pulling the crap out of them until they com off. Don't worry about mangling them, you should replace the wires anyway.
Old 10-15-2005, 08:09 AM
R_H24 R_H24 is offline
It will help if your good with hands in dark, or find a blind person to do this for you. Its tough but you can do it.
Old 10-15-2005, 08:46 PM
kok328 kok328 is offline
I attacked mine by kneeling on the radiator support, one elbow on the intake manifold and other hand pull like hell. You really can't avoid pulling the wire from the boot because the boots are covered by an RF/Heat shield. I reassembled the wires and boots prior to reinstall.
Old 10-15-2005, 10:34 PM
fleettech fleettech is offline
Re: Re: How the hell do i get to the rear spark plugs
[quote=tman2093]you're gonna need a lot of patience, and probably a 6 pack to get you through this.
QUOTE]
I like your thinking but only 2 per plug
ASE Certified Master Auto and Medium/Heavy Duty Truck Technician
Master Certified Emergency Vehicle Technician Law enforcement Vehicles
Old 01-25-2006, 01:02 PM
unibrowarrior unibrowarrior is offline
Why do u guys have to scare him, it easy. Un-bolt the front roll restrictor, and use a prybar to roll the mototr forward. then side the bolt back thought the bracket. this will hold the motor rocked forward and will make it easy to get your hand back there. i am a large guy with large arms and mine fit no problem aftre doing this.
Old 01-25-2006, 02:46 PM
StevePT StevePT is offline
Maybe I'm more flexible than the average person but I just get up on top of the intake manifold and with no extension on a 3/8" ratchet I can take out all three plugs without a problem.
If you have an upper strut tower brace, you will need to remove that.
Old 01-28-2006, 10:57 PM
3bird 3bird is offline
on my 97 I had to undo the front stabilizer bars, then i actually used a comalong wraped around a iron pole to pull my engine forward a few inches, after all that just deal with the metal sleeves. and a few busted nuckles.
Old 02-06-2006, 12:30 AM
mikelund mikelund is offline
I think Craftsman makes some articulating rachet extensions...plus see some earlier posts about rotating the engine forward slightly without come-a-longs.
Old 02-06-2006, 09:12 AM
BNaylor's Avatar
BNaylor BNaylor is offline
I don't know which engine we are talking about here but on the Series II 3800 in '97 and up Regals it is tedious but not that big of a problem. It is not necessary to undo the engine mounts and rotate the engine. All that does is add more time to replacing all the spark plugs and/or wires.
For tools all I use is a spark plug ratchet which has an articulating head, a short extension and the spark plug socket. The most difficulty I've experienced is getting the wire boots off the plugs not accessing or removing the plugs. I use dielectric silicone grease and coat the tips and ceramic of each plug from now on for any future plug removal.
To remove rear plugs I remove the strut cross brace, undo the front 02 sensor wiring harness from the rear bracket, remove the 02 sensor from exhaust, remove the bracket where 02 sensor harness clips to. That gives plenty of room to remove the rear plugs #2, 4, 6. I've done all spark plugs to include wires in my Regals in two hours or less and have never rotated the engine forward to do so. BTW - The 2 hours includes drinking a few brews.
Timeslip 08/12/06
AF Community Guidelines
