Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '91 - '96
Old 09-05-2005, 11:12 AM
roadrunner_19_va roadrunner_19_va is offline
P0506 Fault Code MK3 Jetta Help!!!!!!!
I have a 1999 MK3 Jetta and when checked this fault code P0506 came up. My jetta used to stall out when I pushed the clutch in sometimes and when I checked the code it had a P0102 code. I replaced the MAF and the light went out. Now 3 days later the light came on again and it was P0506. The RPMS rev between 400 and 600 when the A/C is on but it idles fine (around 900) when the A/C is off. This car is really pissing me off. Anyone had any problems like this with theirs or anyone know what I need to check. Please help me out I am getting pissed and might drive this piece of shit off of a cliff. Thanks Travis
Old 09-05-2005, 12:11 PM
boschmann boschmann is offline
Re: P0506 Fault Code MK3 Jetta Help!!!!!!!
That code can be difficult to diagnose (Idle lower than expected). Start by cleaning out the throttle valve. I advise doing this on the car as if you disconnect the electrical connector you may have some difficulty restarting.
Old 09-05-2005, 12:18 PM
Does anyone know the steps to clean the throttle valve?
Old 09-12-2005, 05:58 PM
Remove the rubber air intake from the throttle valve & open by ulling the gas pedal linkage. Spray with throttle body cleaner (not carb cleaner) & scrub with a toothbrush. Repeat as necessary. Car will be flooded at restart. You can spray some in as the car is running in order to get some solvent through the idle circuit , but you are likely to set a MAF code. You can remove the entire unit from the throttle body to soakin a solvent bath (be sure the solvent is safe for the electrionic portion), but it may be difficult to restart.
Remove the rubber air intake from the throttle valve & open by ulling the gas pedal linkage. Spray with throttle body cleaner (not carb cleaner) & scrub with a toothbrush. Repeat as necessary. Car will be flooded at restart. You can spray some in as the car is running in order to get some solvent through the idle circuit , but you are likely to set a MAF code. You can remove the entire unit from the throttle body to soak in a solvent bath (be sure the solvent is safe for the electrionic portion), but it may be difficult to restart.
