Old 09-05-2005, 09:37 AM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
DVC + 2 channel amp
I want to get a Profile AP1200:
* Peak Output Power(4 Ohms)-400W x 2
* RMS Output Power(4 Ohms)-200W x 2
* Peak Output Power(2 Ohms)-600W x 2
* RMS Output Power(2 Ohms)-300W x 2
* Bridged RMS Output Power(4 Ohms)-600W x 1
* MOSFET Power Supply-Yes dual
* Total Harmonic Distortion-<0.05%
* Signal/Noise Ratio-103 dB
* High/Low Level Converter(Male RCA)-Yes
* Pre-Amp(RCA) Outputs-Yes
* Variable Bass Boost@45Hz-0-12 dB
* 12dB/Octave Crossover-HP/Full/LP
* Variable LP Crossover Frequemcy-50 - 250 Hz
* Variable HP Crossover Frequency-80 Hz -1.2 kHz
* Bass Level Remote Control(16.4 ft)
* Fuse(s)-3 X25A
* Dimensions - 2"H x 10 1/4"D x 15 1/4"W
* Power/Speaker Terminal Size(Gauge)4/6
ive got a DVC 2 ohm sub right now, so it wouldnt be a problem, but i want to get a Lethal Injection in the coming future, which is DVC 4 ohm. how would i hook this up? i was thinking since low pass is mono, then both channels would get the same signal, so shouldnt i be able to hook each channelup to each voice coil? ive never seen this topic breached, and i dont know enough about the inner workings of the woofer to complete comprehend this.
Old 09-05-2005, 09:52 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
something about those specs doesn't add up ... ohhh never mind, you listed peak followed by RMS. to get max power from this amp, you need a 4 ohm sub (or a dual 2 ohm wired in series) because it is only 2 ohm stable (4 ohm mono).
Old 09-05-2005, 10:49 AM
Re: DVC + 2 channel amp
damn, guess ill have to get another amp with my lethal, or maybe ill just wait til the XXX come out then get that and a new amp, maybe for xmas... we'll see how the XTR3 that i have sounds.
does anyone have any exprience with the orion XTR3?
Old 09-05-2005, 11:11 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Yes you could wire each channel to each coil individually, or you could wire the sub in series and bridge the amp. Either way you'd get 400rms going to the sub.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 09-05-2005, 06:34 PM
aight now i just gotta see if i can keep my car full and get the amp.... this is gonna be tough lol
