spark plug info
i have an accord '01 I need to change the sparkplugs. do u guy have any recomendation on what kind of plugs should i use?
I heard NGK is the best for japanese car. |
Re: spark plug info
NGK is good and they are inexpensive.
Re: spark plug info
I need to change the plugs on my '00 Accord SE (4 Cylinder) too. I checked the "NGK Spark Plugs" link from this stie and they have NGK plugs - Iridium, Platinum and V-power ones. Which one is recommended? And do I need to change the wires to "NGK wires" as well?
Re: spark plug info
No you don't need to swap the wires to NGK just because you are using NGK plugs, you can mix and match however you desire.
I honestly don't recall what the Accords come with stock , but I would guess platinums. Platinums are generally the good middle ground. They work well, last quite awhile, and are fairly inexpensive. Coppers are the lower level plugs (good for if you are highly modded...but not great for stock) They are cheap, but you have to replace them every 10k or so. Iridiums are top of the line in terms of endurance, but they also cost the most. I'm honestly not familiar with v-powered ones. I'd say go platinum. If you go to any Napa or local car parts store, they should be able to find the NGKs you need.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
Re: spark plug info
i usually get NGK V-Power. cant go wrong with $1.58 a pop.
