Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 09-05-2005, 12:57 AM
bluemoon541's Avatar
bluemoon541 bluemoon541 is offline
d16 swap
will the d16z6 from the 92-95 civics drop into 96-00 civics?
Old 09-05-2005, 06:01 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: d16 swap
no.
wiring will change.
obd1 into obd2 chassis. no go in most states.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 09-05-2005, 12:55 PM
Re: d16 swap
no kidding......
if i get the OBDI to ODBII conversion harness it should solve that problem....im talking a about bolt up proporties...will lt use the same mounting points as the y series engines.....anything wiring i can take care of no problems there......
Old 09-05-2005, 06:31 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
Re: d16 swap
every state im also certain wont allow you to legally put an older motor than the car into it. you may want to check that first.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-05-2005, 08:53 PM
Re: d16 swap
ive already checked...im good to go...
is anyone gonna answer my question?
Old 09-06-2005, 12:49 AM
crxlvr's Avatar
Re: d16 swap
yes the motor will swap but youll need the obd conversion harness, but why not just get a d16y8 from your model year?
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-06-2005, 07:59 AM
Re: d16 swap
because ive seen higher dynos for the d16z6...and i believe it is the stronger of the two.....
Old 09-06-2005, 12:21 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: d16 swap
from the sound of it.. you want to build this motor up... why not swap for a b series?
Old 09-06-2005, 04:58 PM
Re: d16 swap
i like the d series motors...my goal is not top speed or max HP...the d-series motors can still be quik as hell....i wanna push the limits of a D
Old 09-06-2005, 10:05 PM
crxlvr's Avatar
Re: d16 swap
if your goal is neither top speed or max HP? what are you going for, best stock motor?
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 09-06-2005, 10:54 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: Re: d16 swap
if you want a D build up *I advise against it but w/e search for why*
there have been issuces i've seen and read about with the Y blocks mainly the y8 yet the head is pretty cool with a great flowing intake mani all oem.
the z6 block with a y8 head is probbly best setup for Ds I like y8 head for its intake mani and better quench zones then the z6.
Old 09-07-2005, 09:48 AM
Re: d16 swap
thats what i was planning...everything from the block up built for boost........
Old 09-10-2005, 09:54 AM
sohcfreak97's Avatar
sohcfreak97 sohcfreak97 is offline
Banned
Re: d16 swap
i would have to agree w/ ace....that is a pretty good setup, but the y8 head can only flow so much, even w/ a port/polish head, cam, springs, retainers....i mean it'll pull all the way till 9200rpm(where i stop pulling) but it lacks the power u can get from 2 cams...i was once in ur shoe's, then i blew a valve spring retainer, droped a valve, bent the valve guide, and bought an 05 Acura TL...now my civic is sittin in the garage collecting dust...
Old 09-22-2005, 10:40 PM
Volume_Civics Volume_Civics is offline
Re: d16 swap
Theres only so much you can do with D's. I dont know why you want to degrade down. its going to be alot of work. whatever dude you can do what you want.
Bags are for groceries.
