Old 09-05-2005, 12:01 AM
strocksr strocksr is offline
Question fuel nozzle clicks off , 93 dodge grand
when Im refueling...the gas pump nozzle clicks off almost immediatly, no matter what station or wether I pull the rubber boot on the nozzle back so theres no seal...I drive about 100 miles to and from work...and the nozzle clicks off after maybe 2 gallons ..the it continues to click off every 75 cents...I looked under the van to see if the tank was collapsed but ....its not ...is there some kind of vent that could be clogged or what ...maybe pressure building up inside the tank as gas is displacing air...?I havent had this problem for too long ...it just started about a month ago...van is 1993 dodge grand cara...3.3
its driveing me nuts...click...click...click...click.click...pleas e help
Old 09-05-2005, 04:16 AM
caravandrvr's Avatar
caravandrvr caravandrvr is offline
"...it continues to click off every 75 cents..."
I didn't know the pumps still registered less then $1.00 intervals...
Old 09-10-2005, 01:42 PM
Re: fuel nozzle clicks off , 93 dodge grand
so here it is a week later and no mechanics ......have any ideas
Old 09-10-2005, 03:56 PM
Sorry - didn't think this was all that tough. Here's my take on it:
Pull the nozzle out of the filler tube on the van a little. Although that is getting harder these days with those annoying and ridiculous 'vapor collection' apparatus on the filler tubes these days. Also you can use a slower speed on the fuel valve, or try a new filling station....
Old 09-10-2005, 04:18 PM
Itried all that ...pulling back on the rubber filler seal, even pulled the nozzle out a bit ....tried to feather the trigger...no luck...if the vapor tube was clogged would it cause this ...if the tank vent was restricted would it cause this ...is the a problem anyone else has had on these caravans.... I VE TRIED DIFFERENT STATIONS TOO...THE SAME ON ALL...WHAT BUGS ME IS ...IT ONLY STARTED ABOUT A MONTH AGO...DOES THE TANK ON THE CARA HVE A VENT SYSTEM
