Old 09-05-2005, 12:40 AM
camaro73 camaro73 is offline
Send a message via AIM to camaro73
Aftermarket Radio
I have a Clarion Pro Audio headunit for my 1993 camaro rs, i am having major problems getting the head unit to turn on, i have all the wires hooked up correctly, tripled checked everything is good, but i'm not getting a full 12volts to the headunit, the fuse isn't lighting up with a test light and i'm not getting any power to the fuse block at the radio fuse port, it's a 15amp fuse i replaced it and still nothing is working...what could cause me not to get any power to that point of the car?
Old 09-05-2005, 01:59 PM
ct91rs ct91rs is offline
Re: Aftermarket Radio
I'm not sure, but I would just run a fused wire from the battery to the radio, easiest fix.
Old 09-06-2005, 10:55 PM
Vortec350S10 Vortec350S10 is offline
are you saying you hav no power at the factory fuse block under the dash on the radio fuse or does your radio have an inline fuse?
'89 S15 4x4 350TBI/700r4
restored body, paint,
3" lift, crane cam, vortec heads
'88 Iroc 350 carb, TCI 700r4, 380hp
Old 09-13-2005, 12:46 PM
SG007's Avatar
SG007 SG007 is offline
Send a message via AIM to SG007
When I put a Pioneer headunit in my old Pontiac I thought it wasn't hooked up properly because the lights weren't coming on...eventually I figured out that it was so bright that day, and the sun was hitting the display---so I couldn't see that it was on! I was so pissed, but I laughed it off...now I do all headunit stuff when it's darker out.
-2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*-
