Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 09-04-2005, 09:38 PM
AbstractCypher AbstractCypher is offline
Brake Master Cylinder Q: Is It Safe To...
use the after market brake master cylinder for my '98 VW Jetta even though it doesn't have the safety pin to hold the fluid resevoir like the original one?
I heard that it's pretty hard to loosen the resevoir on it's own w/out the safety pin, but am I taking a chance with my life by using the after market or will it stay in place or is there some sort of accessory for the after market brands to hold the fluid resevoir in place, like a clamp of some sort.
ANY help is GREATLY appreciated.
Thanks,
Raymond
Old 09-05-2005, 12:16 PM
boschmann boschmann is offline
Re: Brake Master Cylinder Q: Is It Safe To...
As long as the reservoir snaps into the master's rubber sealing grommet snugly & doesn't leak it should be fine.
Old 09-05-2005, 05:39 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
You could use a large zip tie..... or just drill a hold in the aftermarket one.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
