Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-04-2005, 01:21 PM
tyler2i tyler2i is offline
1994 thunderbird lx front end shimmy when braking
Need help to figure out what is problem with my 94 ford thunderbird lx
when i brake u can feel the front end shake and shimmy i have replaced the brake pads what other thing should i look for ???
Old 09-04-2005, 03:20 PM
peppermrj's Avatar
peppermrj peppermrj is offline
Re: 1994 thunderbird lx front end shimmy when braking
Do you feel it in the brake pedal? If so cut rotors. If not check your suspension and steering pieces. Ball joints, tie rods, control arm bushings, and struts.
Old 09-07-2005, 01:30 PM
Re: Re: 1994 thunderbird lx front end shimmy when braking
thanks for your advise and yes it is felt in the brake pedal as like plusing.
Old 09-07-2005, 03:27 PM
Donald91tbird Donald91tbird is offline
Send a message via AIM to Donald91tbird Send a message via Yahoo to Donald91tbird
Re: Re: Re: 1994 thunderbird lx front end shimmy when braking
does your steering wheel wobble back and forth when braking? Just curious
Old 09-08-2005, 03:56 PM
Re: Re: Re: Re: 1994 thunderbird lx front end shimmy when braking
no no effect on steering wheel, i think i have found the problem it seem that the disk were warped after i had them turned and reinstalled and new brake pads seems the problem is solved ......thanks for ur replys
Old 09-08-2005, 03:58 PM
peppermrj's Avatar
Thanxs for the update. Happy motoring.
