Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-04-2005, 05:49 AM
kota kota is offline
Question camry mufflers
i have a camry v6 vienta and i wud like to replac the stock muffler with sum sort of cannon, is it possible to get, say a 3.5" bomz installed. say with a 2.5" inlet???? how much aprox wud it cost to be installled?
Old 09-04-2005, 06:01 PM
csaxon csaxon is offline
Re: camry mufflers
The exhaust pipe size for optimal power and torque for your v6 would be 2.5". Anything bigger, you'd actually lose low-end power. But, if you plan to go turbo later, go either 2.5" or 3".
I've seen these options on some, but I can't comment on their performance. Sometimes, it's just for looks.
A BOMZ N1 Evo Spec muffler
a Bomz 4.5 tip, straight cut
2.25 from headers, with no resonator, and 4.5 outlet BOMZ exhaust
As for price it depends on where you get the work done. I don't know prices for labor and parts in Australia.
It worked fine until I fixed it!
Old 09-04-2005, 08:23 PM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
You can install anything you want...
It's not any more complicated than cutting a pipe & welding a new pipe on.
There isn't any performance to be gained, just sound.
Deleting the cat is worth about 5bhp peak if you can.
The y-pipe is horrible. A descent custom one should add 10-15bhp. Most of it at the mid-upper rpm range.
The headers are fine. Extremely expencive to buy / custom build, don't gain enough to justify the cost until you've made enough power to blow the engine (375-450bhp) & rebuilt it.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Old 09-06-2005, 11:16 AM
Re: camry mufflers
kota, these guys might be able to help you.
http://www.toyotanation.com/forum/t95813.html
