Old 09-04-2005, 12:02 AM
civicdemon91 civicdemon91 is offline
Send a message via AIM to civicdemon91
Exclamation NEED HELP WITH MY B16 SWAP IN MY 89 SI HATCH need knock sensor info an ecu pins 4vtec
ok motor is in but don't have vtec hooked up i need to know which pins are for vtec on the obd0 harness allready have the pr3 ecu in runs slugish an my knock sensor isn't hooked up can't i bypass the knock sensor somehow if anyone has done this swap can u help me out?
Old 09-04-2005, 11:02 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: NEED HELP WITH MY B16 SWAP IN MY 89 SI HATCH need knock sensor info an ecu pins 4vtec
20 gauge wiring preferred. run these wires to 4 pin connector on shock tower.
vtec oil pressure sensor:
runs to pin b5
knock sensor:
runs to pin b19.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 09-04-2005, 01:08 PM
Hybrid1990crx's Avatar
why woudl you want to bypass the knock? its there for a reason.
Old 09-05-2005, 01:18 PM
idk bro some guy said i could or something i wasnt sure thanku though
