| Latest | 0 Rplys |
Show Printable Version | Email this Page |
#1 | |
Low compression prblem
Alright I have a 1992 Lumina Z34 thats been running rough for a little while, me and my dad replaced the motor about 8 months ago. It was running fine for a little while then started running rough. When the car is cold, I have to feather the gas to keep it from dieing. Also when it is cold when I try to accelerate is lags real bad, then all of a sudden just takes off. I got new plugs and wires on the car and when I did a compression check all of them came up 160 except for the #5 cylinder which bounced around. I tested the #5 a bunch of times and got a range from 15 - 90 and I got 180 on it 1 time. 60 was the average. Does anyone know what would make the compression jump around like that for that cyclinder? Also when I rev in park I cant get past 3300 RPMs just bounced off. Any information would be greatly appreciated. Thanks
#2 | |
As far as the compression issue, I'd run a leak down test. I'd suspect something in the head/valves. Maybe a bent valve???
#3 | |
In God We Trust
Re: Low compression prblem
it could have a rev limiter while in park. My 2001 lumina has one at about 4000rpm's. I also suspect a valve isnt seating correctly, or is bent. Did you check the timing lately? Could the timing have retarded. I hear that if a belt retards by one cog, that the motor will run, but will run very very bad. But I suspect that the valve isnt seating correctly. Change your oil.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
#4 | |
Thanks guys, changed my oil a few days ago didnt notice a change in how it was running. How do you perform a leak down test? Thanks again guys
#5 | |
hope it all works out for ya
1963 Triumph TR3 12K 1995 Buick Century Special 178K 1999 Chevy Lumina LTZ 160K 2001 Suburu Forester 53K 2002 Oldsmobile Aurora 3.5 45K 2004 BMW Z8 3K 2005 Dodge Charger .5K 2006 Jaguar XJ12 1K
