Old 09-03-2005, 09:59 PM
winston727 winston727 is offline
car overheating
MY 89 civic DX is overheating. There is plenty of fluid in the radiator, and we replaced the thermostat. After it gets hot the tube that leads from the radiator to the thermostat/ intake manifold is still cold like it's not letting the coolant flow. There are no apparent leaks and I have bled the system of air, any suggestions?
Old 09-03-2005, 11:28 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Re: car overheating
is the coolant in your radiator even worth anything because its its pretty much crappy and gross its gonna burn and boil off. so flush it if it needs it.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 09-03-2005, 11:29 PM
timmytim timmytim is offline
Banned
Send a message via Yahoo to timmytim
Talking
Have you checked the water pump? Sounds like its not pumping
Old 09-04-2005, 11:41 AM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
Re: car overheating
is it a "timed" overheat, as in it will run at normal but then it will go up to the H and then go back down after awhile..if that is the case it's likely your headgasket is blown allowing air to get forced into the coolant creating an overheat condition.
Old 09-04-2005, 02:23 PM
amy@af's Avatar
amy@af amy@af is offline
Traffic Directing Admin
Send a message via Skype™ to amy@af
Re: car overheating
the only way a water pump goes bad is if it leaks.
if you bled the system of air, you have coolant, and no leaks then i would lean towards the thermo.
have you checked the oil to see if it looks cloudy or like chocolate milk?
"hi! my name is Lady, and i'm a HONDA-holic"
..don't make me send Setanta over in his Waambulance to give you an aloe tissue for your sensitive nose!
*~ ~> USeR GUiDELiNeS*<~ ~*
I <3 the G Ride ~*~ I <3 OLD SKooL
Old 09-05-2005, 10:33 AM
Re: Re: car overheating
The oil looks fine and it only starts to overheat when I drive it. When I just let it idle and warm up it stays near normal but once I drive for about 5 minutes it starts getting hot. I never let it actually get to the H. I always shut it off before that. When I restart the car it still shows that it's warmer than usual but not extremely hot and never comes back down. I jsut replaced the thermostat. Could it be bad already?
Old 09-05-2005, 12:33 PM
amy@af's Avatar
Re: Re: Re: car overheating
is your fan kicking on?
if AT are both fans kicking on?
i have bought thermo's that were bad straight out of the box. we made good habbit of testing them. do you know how to test?
Old 09-05-2005, 01:17 PM
Banned
Re: car overheating
wouldnt a bad coolant temperature sensor cause similar symptoms?
Old 09-06-2005, 10:41 PM
Re: car overheating
not exactly sure how to test the thermo. something about putting it in boiling water and to see if it opens right.
Old 09-06-2005, 10:56 PM
I have a manual and yes the fan is kicking in
