Getting better gas mileage
With the recent rise in gas prices just wanted to start a post on how to increase gas mileage on Honda civic or hondas in general.
I know a cold air intake helps a bit. How much does it really help? Fuel additives. Anyone know of some good ones that actually work? Oil additives. Same here, any one have any luck with these? Any other ideas to boost your miles per gallon. |
Re: Getting better gas mileage
dont get on the gas as much
keep with ur maintenaince intervals. check timing spark plugs cap and rotor fuel filter air filter dont drive fast get smaller or recomended size tires leave ac off stop reving that engine at the red light trying to impress someone stay in 5th gear alot loose some weight do ur oil changes
ive got manuals 92-95 civic 96-98 Civic clicky here clicky here WTB:92-95 EX/SI cluster w/tach FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers |
I try to keep the RPMs down as much as I can, is this acually getting worse gas milage because I got to give the car more gas to move.
the honda manual says to stay in the highst gear that you can accelerate smoothly.
i assume that this means if you are trying acceleration in 5th gear at 10 mph., you will loose gas mileage
so you are asking me what should you make? Ummmmm.... well i vote meth lab.....helps out the community and gives people like you a job I love out driving people. "what's all those cylinders for anyway"
use comon sence on that one.
make sure tire pressure is correct, check air filter for dirt -- clean if necessary, read the manual for shift points.
Silly ricer, wings are for planes |
i keep off the gas, change my oil regularly, air filter occationally and just changed my fuel filter.
i only get about 28 MPG in the city. i cant figure it out. i have like 150 lbs of sterio junk, SRI, but that shouldnt kill me that much
Re: Re: Getting better gas mileage
Also, if you're driving an EX, 28 in city would be about right.... I drive a DX, and I get about 30 in city... could be due to my higher transmission gearing. Also, what octane rating gas are you using? I was using 93 for the longest, then when the prices shot up, I did a milage test to see how much my milage dropped while using 87... and I actually GAINED 2 miles per gallon on 87 octane than on 93.... 93 I was averaging 32mpg, but now on 87 I'm averaging 35mpg.
Honda Enthusiast
i use the 87 octane, every once in a lpong while i fill up with 92 or 93.
surprisingly the 87 octane is better for our cars. there were made to run on cheap fuel. but once you mess with the timeing or go woth FI you would need the higher octane (why the hell am i telliny you this, i am sure you already know) I have always been affraid of any type of fule addative, dont know why. anyway, what type of fuel injector cleaner would you suggest.
Dealers specifically say you will get better milage out of the car using 87.
Honda Enthusiast
Anyone use any oil additives, I heard that this one called friction 3000, adds 5-10 mpg, adds to overall performace, and makes engine last longer. It basicly is a concentrated synthetic lube that makes everything run smoothly. Anyone have any luck with something along these lines?
sounds to good to be true.
that is probably because it is.
Honda Enthusiast
Oh, oil additives don’t work! They just take your $. Last edited by alfonso2501; 09-19-2005 at 01:15 PM. |
