Old 09-03-2005, 03:54 PM
flatlander757 flatlander757 is offline
Send a message via AIM to flatlander757
How hard would it be to build my own LT1?
Since I just ticked in at 194,500 miles... I really need to start considering a new engine. It is my daily driver that I need to get to school and work, so a rebuild I believe would be out of the question. I am working at Sonic making $6/hr right now, but should hopefully be working at a car dealership for my internship at the votech school im going to this year(and next) making $7+ an hour so saving money is a concern. I figured if I do as much work myself as possible, that could save quite a bit. This is a project I'd like to have finished by spring break, or at latest, next summer.
I think my main obstacle is where this will be done, my garage. My dad is a woodworker and there is always sawdust in there... I doubt that is a good thing if I will be building an engine in there, but it may need to suffice. I could cover it whenever I'm not working on it to hopefully prevent any crud from getting inside.
My goals with this engine I plan to build are:
-355ci(maybe 383... depends on how many supporting mods I'd have to do)
-11:1 compression (don't plan on anything but NA)
-probably an LE2(maybe LE3) head package w/ a cam that will produce good power(375+) but still be relatively fuel efficient
-and will aim to keep the budget below $3000 for everything, including labor to get it installed and dyno tuned, seeing as I don't have a lift or the means to put the engine in from underneath.
I'm only 17 and don't know a whole lot aside from the general workings of a pushrod engine, but hope to get some knowledge out of the votech program I'll be in... do you think this is a reasonable feat I can undertake?
-Tony- Sold my Z28 looong ago. Now sporting an '03 TJ.
Old 09-03-2005, 04:32 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: How hard would it be to build my own LT1?
Once the engine is out. Anyone with some know how and some tech aide books or video can do it. I have faith in the fact if you take your time. You can get it done.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 09-03-2005, 05:12 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
its nice to see a Z28 still running strong at 194k+
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 09-03-2005, 05:14 PM
and about the dust situation, you could always drop plastic from the ceiling and make your own dust free work space.......
Old 09-03-2005, 08:25 PM
Rod&Custom's Avatar
Rod&Custom Rod&Custom is offline
Send a message via Yahoo to Rod&Custom
I do that alot when welding or sanding putty when its raining and we don't want to put the car out. For some reason he won't let me burn the paint on his 30k street rod!?
Old 09-03-2005, 10:11 PM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
no dust in any case.
Its fairly easy to build a nice lt since you actually got the engine out. Just take it all apart. Clean, inspect,measure (get all the tools you will need), order the right size kit, send the block and heads to the mashine shop (head job, honning, maybe boring as well) The worst part is the frustration when a bolt wont come out or you break something or there is no proper tool.
$1000 will do with most dis/assebly done by you. depens on what kind of parts you will use and what needs replacement.
How good are your skills?
Old 09-04-2005, 01:36 AM
I can follow instructions as long as they are right
I also had a somewhat related question... it would be quite unique to have an original SBC(like... carbuerated or at least throttle body injected) in a newer Camaro... I was looking at RPM and the entire longblocks are dirt cheap for 383 strokers... I was thinking about the $2499 Street/strip stoker:
Street/Strip Stroker SBC 383 4 bolt main block, Eagle cast steel 3.75" crank, Eagle SIR 5.7" rods, KB Performance or Sealed Power hypereutectic 9.6:1 pistons, Sealed Power rings, solid or hydraulic flat tappet cam, double roller timing set, new balancer and flywheel, pushrods, new OEM rockers, OEM heads with Manley 2.02/1.60 stainless valves, HP springs, locks, and seals
Here is the site if you are interested: www.revolutionaryperformance.com
I was thinking it would be cool to see if I could get that but with a bit more bore/stroke to get it to 396... Then rebadge my car as an SS... sort of as a tribute to the 69 SS. It probably wouldn't be the fastest thing still, but would be very simple, clean up the engine bay, and by far the most unique thing I'll have ever seen...
Old 09-04-2005, 11:23 AM
if you are going to be using the car for going to school etc i would say stick with with the LT1 fuel injected platform.... you get awesome power with still good gas mileage....
Old 09-04-2005, 12:50 PM
Good point, probably a smart idea.
Old 09-04-2005, 01:58 PM
Banned
I have seen it before. It looks pretty cool when you open the hood and threis a carb in there.But I believe the fuel injection is superior. Still nice idea though.
Old 09-04-2005, 02:08 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Damn, how do you afford your car on 6/hr?
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 09-04-2005, 02:18 PM
nastyNater's Avatar
nastyNater nastyNater is offline
Send a message via AIM to nastyNater
[quote=flatlander757]
IQUOTE]
dont get a carb if you like your gas. 8 cylinders w/ Fuel injection get more mileage and perform better. but hey if you want something unique that would definitely quailfy....i dont think ive ever seen a carb setup in a new F-body.
01 Honda Accord LX- YEAH IT HAS VTEC BITCH. WHAT
y2icon's Avatar
y2icon y2icon is offline
Send a message via AIM to y2icon Send a message via Yahoo to y2icon
he affords it on 6 dollars in hour for his love for the Camaro
Nitrous= the car equivalent of a penis pump
Old 09-04-2005, 03:26 PM
LOL... I work my ASS off for it. I am in HS so don't have any bills to pay(aside from cell phone - $25/m) so I can afford $600 every 3 months for insurance. I paid $2200 for my car and it was a friggin steal!
I know an LT based motor would be more efficient/smarter, but jeez a 396 SBC is just sweet! What if I got a throttle body setup for it?
I think another option would be to do LTs and CAI since those are supporting mods for more power, then rebuild what I have to 383ci along with new heads and whatnot.
Old 09-05-2005, 12:48 AM
people who have 383 LT1s are queer... esp. if they recently swapped a vette motor in
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
