Old 09-03-2005, 04:52 PM
thugfromdr thugfromdr is offline
98 24 Valve SE
Service Engine light on mechanic says All the O2 sensors are bad , the car occasionaly starts to hesitate(Only when I'm stopped) than shuts off, but comes back on. When It doesn't shut off and I take off It hesitates as I'm rolling ,besides that nothing. Do the symptoms match the diagnosis????
Old 09-03-2005, 09:55 PM
mr_tw's Avatar
mr_tw mr_tw is offline
Re: 98 24 Valve SE
it's a possible solution, when your O2 sesors go, then the engine thinks that it's running lean and dumps in toomuch gas so you should be getting less mpg as well, obviously the extra gas could be whats causing the problem on your car, i would suggest just changing them yourself, all you need to do is find them, when i changed mine (different motor) all i did was put my hand on the exhaust pipe right after the exhaust manifold and felt down thepipe till i found it then it's just a matter of unpluging the old one and unscrewing it and then doing the reverse with the new one (obviously you screw it it then plug it in) the sensors are quite cheap, and you may need to remove the tire to get in there, but it's overall an easy job and you'll save yourself the 75$ an hour that the dealership charges you (the sensos should cost less than that lol) but good luck
What Is With The Hatred Between Imports and Domestics? In The End, We All Love Cars.
Old 09-04-2005, 01:46 PM
Re: Re: 98 24 Valve SE
Thanks for the redponse do you know how many O2 sensors my car has??
Old 09-04-2005, 04:13 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: 98 24 Valve SE
three, one for each bank before the cats and one on the collector after the cats.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 09-12-2005, 03:06 PM
tranny??
Can bad O2 sensors cause a tranny to act weird ??? it always shifts good only some times(very rare) It'll act weird??
Old 10-01-2005, 07:50 PM
Re: tranny??
come on guys help drove the car today and as i took off I felt acceleration but the the car moved slow I let go of the gas then accelerated again and the same thing happend then It took off normal scared that It might be tranny but all o2 sensors are bad could they be the culpret's???
Old 10-01-2005, 08:16 PM
wijim wijim is offline
Re: tranny??
Sounds like the same symtoms I'm experiencing. My local dealer told me I needed new wires. This, after 2 1/2 hours trying to figure it out.
Jim
Old 10-02-2005, 08:03 PM
Re: Re: tranny??
Jim
Really spark plug wires!!! I didn't know they could make a car act like that.
