Old 09-03-2005, 03:39 PM
dhspring dhspring is offline
power door locks
My power door locks stopped working recently on a 2001 Astro Van, when I hit the button to open I hear a clicking noise. Those are the relays right under the dash, I found them and all they do is click when you attempt to lock/unlock the door. This doesn't look like a blown fuse because the relays are hot. I pulled all 4 relays and interchanged and tried installing 1 then 2 then 3 and all 4 in different combinations, no luck. Any ideas? Replace them all maybe? Any advice is greatly appreciated. Thanks.
Old 09-06-2005, 09:17 AM
Aqua Angel's Avatar
Aqua Angel Aqua Angel is offline
Send a message via ICQ to Aqua Angel Send a message via AIM to Aqua Angel Send a message via MSN to Aqua Angel Send a message via Yahoo to Aqua Angel
Lightbulb Re: power door locks
Look between the driver side door and the frame of the van. See if the wires aren't cut or striped "damaged" my 87 Astro use to that, but soon found out that 4 wires got damaged. usual kind of wear when you open and close the door. that could be a start for you. While you are at it? if you see any other wires about to go? might as well fix it, chance are that your windows could be next.
it is a tight spot to work on, but if i did it? anybody can. =)
Good luck
93, Chevy Astro van, Saphire Blue, Led tail light.
looking for:
Euro clear corner lights and Billet grill "chrome" and a good shinny 5 spoke rims and a disc brake rear differential
Old 09-06-2005, 10:18 AM
Thanks for the advice. Oddly enough the next day, the locks were working again. The day they stopped working it happened to be raining and perhaps it dried out over night. I'll check what you said about wires getting crimped. Thanks again.
Old 09-07-2005, 10:03 AM
brcidd's Avatar
brcidd brcidd is offline
My '94 astro windows circuit was interuppted first- then the door locks- grab ahold of wiring boot at driver's door while attempting lock/unlock doors- see if you can turn it "on" and turn it "off" then you'll know where to find the broken/damaged wire--- I'd start with ther most used door first- the driver's door- have had to repair wires inside that big rubber boot on both sides of my Van...........
