Old 09-03-2005, 03:16 PM
Mike P Mike P is offline
98 Caravan A/C clutch off and on
After starting engine and turning on A/C the clutch turns itself off and on continuously. This causes the belt to slip and ruin. A/C guage was reading app. 25 psi so I added 2 cans of freon and guage now reads 35 psi at idle. Clutch still kicks off and on??
Old 09-04-2005, 07:27 PM
dbfordtech dbfordtech is offline
Re: 98 Caravan A/C clutch off and on
How often does it cycle?
Old 09-05-2005, 10:18 AM
About 30 seconds for both on and off.
Old 09-05-2005, 10:26 AM
caravandrvr's Avatar
caravandrvr caravandrvr is offline
Might be the pressure transducer - it's an item located on the H-Block.
Old 09-05-2005, 12:49 PM
pacamper pacamper is offline
It is suppose to cycle, but maybe not that often? I understand there is a high pressure switch that may be your problem? On my 95 the guy said it was that on the left side of the rad as you are looking in. Seems you have some switchin prob if it is cycleing that much?
Old 09-05-2005, 07:13 PM
vipergg vipergg is offline
Re: Re: 98 Caravan A/C clutch off and on
Sounds normal to me . This is not abnormal cycling , it has to cycle otherwise the evaporator will freeze up .
Old 09-06-2005, 02:15 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Re: Re: 98 Caravan A/C clutch off and on
depends on the speed of the fan motor. If it's running at speed one, then yes it's going to cycle like that to prevent evap core freeze-up. If it's doing it on speed 3 or even high, then there could be a low charge in the system or even a bad pressure transducer.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
