Old 09-02-2005, 10:33 PM
bigry2004 bigry2004 is offline
Send a message via AIM to bigry2004
front end/brakes
anyone know offhand how much it costs [roughly] for a front-end alignment with labor? so many places differ in price, i wonder if anyone knew about what a decent one is so i dont get ripped off.
also, has anyone ever changed the drum brakes on their chevy blazer before? i can do discs, but never drum, so i wonder if it is something i could do or would be safer/better off having them professionally done.
thanks
[97 blazerlt 151 k mls.]
Old 09-04-2005, 12:28 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: front end/brakes
$50-$100 for a computerized alignment.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-05-2005, 07:36 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
NTB charges 60 bux for a laster alignment, with a 6 mos warranty.
Old 09-06-2005, 01:27 AM
JA no Y's Avatar
JA no Y JA no Y is offline
thanks
Changing the drum breaks isn't all that hard. Just remembering where everything goes is the pain. If it helps, I use to jack both sides of the vehicle and set on stands. That way I could remove both wheels and hubs. If I ran into a problem remembering how it all went back on, I'd just go to the other side and look at where everything went.
Old 09-06-2005, 01:15 PM
front end/brakes
well, i went in for the alignment and when i looked with the mechanic underneath the front end there is a mess so to speak. all my ball joints are shot [usually are greased every couple of months] and i need new idler arm and pitman arm. plus the alignment, and with the cost of labor bill came to about $500.
Ball joint 29.95 (4)
pitman arm 33.29
idler arm 51.05
Estimate total 537.09
Labor [ 321.00]
Old 09-06-2005, 01:36 PM
JA no Y's Avatar
Man....$321 labor. Too bad I can't charge myself for fixing all the stuff on my blazers. I could retire!!
Old 09-06-2005, 06:04 PM
hmm?
well, the front end is fixed after a couple of hours. this started happening about a couple of days ago now and i thought maybe this visit to the shop would take care of that. there is still a squeaking on the drivers side but not while i am braking to insist there is a brake job in the near future.. although i am going to install new discs next week.. so its hard to hell where the squeak is coming from. this is a different one than was under the hood last week. what could this be, rotors? leaf springs? it even makes this squeaking while idling...
Old 09-07-2005, 02:23 AM
BlazerLT's Avatar
AF -Advisor
Those prices are pretty cheap for the parts.
What name brand did they use?
Old 09-07-2005, 10:22 AM
Re: Re: front end/brakes
i dont remember. he said the best there was and i got a lifetime guarantee on everything. not to be a pain, but any suggestions on those squeaks? i guess its highly possible it might be the wheel bearing, but i cannot tell where the sound is coming directly from. guess if one thing goes, it all goes right?
Old 09-07-2005, 11:29 AM
BlazerLT's Avatar
AF -Advisor
Brake pads need changing.
Old 09-08-2005, 07:46 AM
okay. they even squeak when im not braking.
Old 09-08-2005, 11:02 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: front end/brakes
CHANGE THE BRAKE PADS!
Listen please, the indicators on the pads squeal when there are NO brakes applied and will go away when they are applied.
Change the pads and maybe replace the rotors.
Old 09-08-2005, 09:24 PM
Re: Re: Re: Re: front end/brakes
alright alright ... i wasnt aware until today that there was a sensor to cause the squealing when the brakes are not applied. i bought the pads today for $39 and am putting them on most likely tomorrow. thanks blazerlt
Old 09-08-2005, 09:28 PM
rlith's Avatar
If your squealers are going off, that means that your rotors are getting cut. They will either have to be turned or replaced.
Old 09-08-2005, 10:46 PM
BlazerLT's Avatar
AF -Advisor
Not necessarily if you catch it when is starts.
The indicators are very light and don't gouge the rotor in their first stages.
