Old 09-02-2005, 07:08 PM
kennie616 kennie616 is offline
ported box?
hi i have 2 12 inch comp vrs the 2005 models in a sealed box with the kx600.1 -- 2.5 cubic feet and it kinda sucks.. i wanted to know what dimensions for a ported box i should use.. and if it would sound better/louder
Old 09-02-2005, 11:03 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the right box will make all the difference in the world
Old 09-03-2005, 02:21 AM
kcg795 kcg795 is offline
Re: ported box?
Ported might sound a little boomy. If possible, try a bandpass. But if ported is the way to be, you might get some good results if you tweak with the crossover on the amp a bit. You can't just build a ported box either. They have to be just right to sound good. It's usually the cheap ones that sound like shit. I converted my Roadmaster bass tube from a ported to a sealed and it sounds a hell of a lot better and I got it under my desk. Hope you do find something that'll work for ya. Good luck.
Old 09-03-2005, 11:30 AM
Audio Guy
kcg ..... a bandpass IS a ported box - just a higher order (a little louder)
Old 09-03-2005, 11:48 AM
Re: ported box?
Well, it's a sealed and ported hybrid, actually. The woofer, or woofers, get some air cushion on one side so they can get some pretty accurate bass.
Old 09-03-2005, 07:40 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Re: ported box?
that made no sense^. and bandpass is the "boomiest" of them all. Boomy is not the word to describe the difference between properly ported an sealed
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 09-04-2005, 11:30 AM
Audio Guy
Re: Re: ported box?
NO
the only sound comes from the port, the other side of the speaker is sealed off .... that does NOT make it a half sealed box in terms of order. It is even more of a ported box than the normal one, and the "order" is even higher. You might wanna look this stuff up on the net, there's lots of good info out there.
