Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-02-2005, 05:31 PM
bbilly's Avatar
bbilly bbilly is offline
Question 3" exhaust question low end vs high end
If I put a 3" TURBO BACK WILL IT REDUCE LOW END SPOOL UP? I have an automatic with turbo lag already and need a quicker spool up not more top end
PS. is the hks carbon muffler system anygood?
Old 09-02-2005, 08:29 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: 3" exhaust question low end vs high end
it should actually improve spool speed. possibly a lot.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 09-03-2005, 01:19 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
I think that the hks is the most expensive one out there. If you are going to spend the money i would just go with the apex n1
MODS
, 2g pistons, cyclone intake manifold, ported 1g head, 60mm tb, greddy type s bov, apex-i n1 exhaust , ngk spark plugs, 3 angle valve job, autometer boost/vac, autometer air/fuel ,autometer oil pressure ,cross drilled rotors ,turbonetics boost controller ,air filter ,remove dump tube, 14b turbo
and the ac still doesn't work and its been almost 3 years
Old 09-03-2005, 01:52 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Going Full name brand o2 back is the easyist. It's expensive though $500-$600. You can peice together a full 3in turbo back for around $330. I bought my 3in Megan Racing downpipe and Muffler for $179 shipped to my door. I've had 3 muffler shops quote me the same price of $150 for the 3in catback as long as I put on the Downpipe and supply them with the muffler. Just a heads up! And yes, it will increase flow, and turbo spool, but will increase boost creep if you don't port out your o2. Might be worth it to spend the extra $60-$140 on an aftermarket 2.5-3in o2 housing.
DSM geek
Old 09-03-2005, 01:57 PM
bbilly's Avatar
Re: Re: 3
Originally Posted by scottsee
Going Full name brand o2 back is the easyist. It's expensive though $500-$600. You can peice together a full 3in turbo back for around $330. I bought my 3in Megan Racing downpipe and Muffler for $179 shipped to my door. I've had 3 muffler shops quote me the same price of $150 for the 3in catback as long as I put on the Downpipe and supply them with the muffler. Just a heads up! And yes, it will increase flow, and turbo spool, but will increase boost creap if you don't port out, or buy a 2.5-3in aftermarket o2 housing.
Ok doesnt the waste gate control boost creep? How much and how hard is it to port out or do a 3in o2? which o2 is it the cat o2 or the one in the turbo? I appreciate your help...
Old 09-03-2005, 01:59 PM
bbilly's Avatar
Re: Re: 3
I got a deal waiting $450 for an hks carbon wrapped titanium tipped deal with down pipe. I think its cheap enough but is it any good?
Old 09-03-2005, 04:49 PM
This is a picture of the Stock 96 GSX downpipe next to my Megan Racing DP W/cat-eliminator. you can see the Catilitic Converter attached to the end of the stock downpipe
You don't need to port a 2.5in or 3in o2 housing. You need to port out the stock o2 if you don't buy one. To understand Boost Creep a little better, check out 1000 already asked questions on VFAQ.com. It explains it very well
DSM geek
Old 09-03-2005, 06:50 PM
kjewer1 kjewer1 is offline
AF - Advisor
I think there is some info on my site as well.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-05-2005, 01:15 AM
thats pretty cheap for the hks all of the one that ive seen are 600 plus but i thought that hks didn't make 3" piping for are cars
MODS
