Go Back   Automotive Forums Car Chat > Ford > Probe
Old 09-02-2005, 05:54 PM
xbellwarex xbellwarex is offline
Send a message via AIM to xbellwarex
1990 engine/trans swap HELP!?!
i own a 1990 ford probe GL. its got the 4 cyl. 2.2 l w/ automatic trans. i have 120000 miles on it and im looking to but the V6 probe motor with a manual trans it in. first off, how much work is this project going to be, i know that it will by no means be easy, but is it reasonable to even attempt. second, what is the V6 engine called for the 90 probe. is it the same v6 they used in the newer model probes? if not, can i put a v6 from the newer models in my older model. and last, where can i purchase an engine, besides getting one from my local junkyard and having to rebuild it. thanks to anyone that can help me.
Old 09-07-2005, 06:33 PM
shawnwilliams's Avatar
shawnwilliams shawnwilliams is offline
Re: 1990 engine/trans swap HELP!?!
going to the v6 is alittle crazy and cost effective. your better off just geeting all the turbo stuff from the gt. but you cannot fit the 2.5 from the second generation in a first g.
93 FORD PROBE GT
JDM manifold ported match
65mm TB
Unorthodox Underdrive Pulley
Hotshot headers
3' Exhaust all the way
No cat
Cold air intake
K&N air filter
Short throw shifter
Eibach lowering springs
FX Design Body Kit
B&M Short Shifter
Stage 3 Clutch
MX-3 Flywheel
Performace Wires and Plugs
Synthetics
Performance Rad and fan
Mild Weight Reduction
Coming this week:
Performance Heads and Cams
3 angle head job
Why does everyone have to piss on Ford.
