Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 09-02-2005, 02:14 PM
ENCEE ENCEE is offline
Angry 97 Epedition Check Engine Light
Ok People I Need Your Help
My Engine Light Came On About 6 Months Ago, I Dont Drive This Vehicle Much Well Last Week My Truck Would Not Start
Thanks To This Web Site After Following All Of You All Advice
Did Replace Iac Valve ....it Did Start...thanks
But Now The Engine Light Stll There One Time My Friend Took The Truck To A Dealer And According To The Dealer An Oxygen
Sensor Is Bad ?????? It Has Like Four ?????? What Can I Do
Should I Go To A Delaer And Get It Fix......
Old 09-05-2005, 04:09 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 97 Epedition Check Engine Light
Please post the exact code number. There are many variables to the "O2 syndrome"
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 09-07-2005, 03:32 PM
Thats The Problem I Dont Have The Code???
Old 09-07-2005, 07:56 PM
way2old's Avatar
TOKEN HILLBILLY
Go to Autozone or Advance or a parts chain house. They will read the codes for you. Write the code numbers down and post back.
Old 09-11-2005, 03:13 PM
ernie300 ernie300 is offline
Smile Re: 97 Epedition Check Engine Light
I have the same issue so I went out and bought a scanner turns out my EGR valve needs changing. So I would recommend buying a OBD( ON BOARD DIAGNOSTIC) scanner to first see what the problem is and go from there.
Old 09-20-2005, 01:07 PM
Snapper23 Snapper23 is offline
Same problem different year
I have a 98 Expedition and my check engine light came on. I went to Advance Auto to get the free diagnostic test. It came up as needing a erg valve. I got that fixed as well as the pcv valve and hose. Even after those repairs my check engine light is still on. I took it back to Advance Auto for another reading now I have codes P0172 and P0174 (System too lean Bank 1) what does that mean, and how to fix it.
