Go Back   Automotive Forums Car Chat > Ford > Contour
Old 09-02-2005, 02:09 PM
kerridodds kerridodds is offline
Oxygen sensor - which one?
My 96 v4 contour failed emissions testing. The fault code is P0133 and it said that the O2 sesor circuit had a slow repsonse. I assume that I need to replace the sensor. Which sensor do I need to replace, the one before or after the catalytic converter? Any help is greatly appreciated.
Old 09-02-2005, 04:28 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
P-0133 = Upstream Heated Oxygen Sensor circuit Slow Response - Bank No. 1.
upstream is before the cat. All other codes can be found on www.contour.org.
http://www.contour.org/FAQ/FAQ.php?s=probs&displayid=10
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
