Old 09-02-2005, 12:38 PM
ndoerr ndoerr is offline
not firing on #1
i have a '75 Pontiac Le Mans 350 i put in a '80 toyota. pretty much i put the stock motor in after putting new piston rings, gaskets, honing out cylinders and reaming the ridges, putting a new cam and lifters in, and port and polishing the heads. now that it is all in i try to run it and it is not firing on the #1 cylinder. I have a new distributor cap, wires, condensor, plugs, and cant figure out why the first one isn't firing. also the timing is good. any input would help
Old 09-02-2005, 02:17 PM
Mike Shimer Mike Shimer is offline
Re: not firing on #1
check for vacuum leak-do a leak down test on #1
Old 09-03-2005, 06:36 PM
how do you do that?
Old 09-03-2005, 10:09 PM
jveik jveik is offline
lol let it be. my 73 c-10 with a 350 had a flat cam lobe on the number one cylinder that caused backfiring at w.o.t. so it actually was quicker with the number one cylinder not firing
