Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 09-02-2005, 12:03 PM
dog5629 dog5629 is offline
Is the JDM P72 ecu pinout different from the USD P72 pinout?
I bought a jdm b18c motor and the IAB does not work so I manually wired it to see if it works. Solenoid worked, theres vacuum. I checked voltage on both wires and both had battery voltage to ground. ETM says one wire goes to pin A17(-) and the other to the PGM-FI main relay(+). I pulled the wire I have at A17 to see if there was voltage coming straight from the ECU (when ignition is at on position) and there was still battery voltage. from what I get from the ETM the ecu grounds the circuit to give vacuum to the IAB at low rpm and at high rpm disconnects the ground. Well I took the ecu back they let me swap it with another ecu and it still did'nt work. but I think that ecu was bad also so what I'm going to try next is to swap ecu s with my buddies p72. or thats why I'm asking you'all is the JDM P72 ecu pinout different from the USD P72 pinout?
Old 09-03-2005, 04:39 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Is the JDM P72 ecu pinout different from the USD P72 pinout?
check your other posts.
notice the S at the end of post
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
