Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-02-2005, 09:42 AM
copcarcrzy copcarcrzy is offline
AIR PUMP disable
I was reading on a website that the A.i.R. pump (SMOG ?) can be disabled, without effecting the emisions test. Is this true and will it cause engine damage.
If it is safe to do any one know how to do it the dealer wants tons of money to fix and the parts for a self fix are expensive as well.
any help would be great
Old 09-02-2005, 04:44 PM
CD Smalley CD Smalley is offline
Re: AIR PUMP disable
False I believe. The point of the AIR pump is to inject outside air, mainly oxygen, into the exhaust ports to help the older convertors light off quicker and begin reducing emissions sooner. Removing it or disabling it will have the exact opposite effect.
The last AIR pump I bought was about $60USD and took just barely an hour to replace.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 09-02-2005, 04:48 PM
$60.00 WOW was it NEW ??
Old 09-02-2005, 05:23 PM
Yup.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 09-02-2005, 05:25 PM
where did you get it ??
Old 09-02-2005, 07:13 PM
Local parts store to me.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 09-02-2005, 10:30 PM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
A couple of good places to check part prices online is at the Napa, Auto Zone and Advance Auto Parts sites. They'll even give you store locations close to you and tell you if the part is in stock most of the time.
Old 09-03-2005, 12:55 AM
2000CAYukon 2000CAYukon is offline
You don't mention what year your caprice is; however, the 95-96 models did have a TSB that allowed for the air pump to be disabled.
Here is the TSB http://www.impalassforum.com/tech/en...p/air_pump.htm
//2000CAYukon
Old 09-06-2005, 08:29 AM
vette_7t9 vette_7t9 is offline
Umm...on aftermarket headers that dont have the AIR inserts, will i pass emissions??
Old 09-06-2005, 09:54 AM
bobss396's Avatar
I have a degree in Automotive Engineering, so I know what I'm talking about... usually. Be very careful when you're changing to aftermarket parts. I'm not a big believer in headers unless they're installed by a shop that knows what they're doing. You can end up with less HP than what you started with. I think you'd be better off with some stock appearing reworked manifolds, which are available. Headers for street cars are too much of a compromise.
To answer your emissions question, it probably will not pass without a fully compliant hookup. But that depends on how tight the emissions are for your area and vehicle application.
Old 09-09-2005, 09:09 PM
MyNeoN95 MyNeoN95 is offline
People people, I got my air pump like new at a dealer in Michigan and got it for $15 dollas.
But yeah My car stalled and found that the air pump seized. and I didn't now what was wrong until I took off the belt and tried turning my pullys and found my air pump went bad.
Old 10-24-2005, 03:53 AM
redimpss5 redimpss5 is offline
Gee, Bob is not as smart as he said. 1st, yes there is a TSB to cover the air pump! The air pump really is just a big blow dryer that is supposed to warm the cats. (for only 3 minutes) And the federal gov decided it was not needed. Next, there are 3 header company's that have CARB approved headers for your car that will improve many areas of your cars's performance areas!! Better yet, 50 state approved for smog!! Many cars are made to be driven, and thats great for some, but anything can be improved!! Better yet, it can be done legally!!
american component's russian component's all made in taiwan!!
Old 10-24-2005, 10:55 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
You take a vehicle through the IM240 or IM167 test and see if it passes with a disabled AIR pump.
Unless you can show evidence (such as the GM TSB), they will consider it tampering and will fail the car.
Old 10-24-2005, 11:33 AM
bobss396's Avatar
redimpss5, FYVM for the nice comment, I appreciate it.
