Old 09-02-2005, 07:20 AM
mas&NKS's Avatar
mas&NKS mas&NKS is offline
Did 1983 3/4 ton's have emmissions?
My 1983 silverado k2o has no signs of any kind of emissions anywhere. no check engine light, no 02 sensors, nothing. did these trucks come with emissions?
Old 09-02-2005, 12:31 PM
jveik jveik is offline
Re: Did 1983 3/4 ton's have emmissions?
they probably just had catalytic converters, a egr valve and maybe a fuel vapor canister to collect fuel vapor from the tank. How many fuel lines run along your frame? theres a main line to the pump, a return line to the tank, and a vapor line to the canister.
as for sensors... there are no engine computers on those trucks except for probably the 87 fuel injected models. everything is mechanical.
Old 09-02-2005, 07:03 PM
Powersurge Powersurge is offline
so is this gonna be a probelm when i go to have it inspected? it has straight exhaust with glasspacks. no cats
Old 09-02-2005, 07:39 PM
broughy84's Avatar
broughy84 broughy84 is offline
cats were not stock on a 83, you shouldn't have any problems I wouldn't think anyway.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 09-02-2005, 08:07 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Re: Did 1983 3/4 ton's have emmissions?
I thought everything after 1979 had a cat on it?
Old 09-03-2005, 01:21 AM
yeah i thought it was after a certain year... its not like it matters here in nebraska with no vehicle inspections and stuff... or just take an old cat and cut it in half and stick the halves together around the pipe. if you do a good job and stuff, when a cop glances under he will see that and think its a.o.k.
Old 09-14-2005, 02:43 PM
mbumgua's Avatar
mbumgua mbumgua is offline
I bought a 83 k20 new in 1983--It had no cats from the factory, just egr and pcv and charcoal canister. I have an 86 c20 now that had no cats from the factory.
Old 11-13-2005, 07:43 AM
WHARTY20 WHARTY20 is offline
I HAVE AN 83 2500, IT MAKES A LOUD SQUEEKING WHEN IN 4X4. DO YOU KNOW WHAT IT COULD BE. THANKS CHRIS
Old 11-15-2005, 08:03 AM
mbumgua's Avatar
Sounds like cv joint or u-joint bad.Jack up front end carefully and rotate front tires by hand and listen to pinpoint location of squeek. Then visually inspect the u-joints and cv joint.
Old 11-15-2005, 04:43 PM
I WILL GIVE THAT A TRY. THANKS FOR THE HELP. I WILL POST RESULTS.
