Old 09-02-2005, 06:03 AM
markinlv markinlv is offline
Headlamp Alignment - 1998 Blazer
Can anyone help me (tell me how to) properly align my headlamp assembly?
Old 09-02-2005, 11:01 AM
mtware mtware is offline
I took mine to a bodyshop and they did it in about 10 minutes.
Old 09-02-2005, 03:16 PM
SComp23 SComp23 is offline
Start out with a flat surface, and preferably a white wall. Pull your vehicle up to the wall, and mark where the geometric center of your low beam headlight for both headlights is on the wall, and then put a large piece of horizontal tape there. Back your car up 25 feet, and notice where the beam is hitting the wall. The beam pattern of a 1998 Blazer looks something like this ___|---|___ where there is a large rectangle of light, and then a somewhat even distribution of light off to both sides. The center of that rectangle should be right in the middle of your marking.
Old 09-02-2005, 07:44 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Headlamp Alignment - 1998 Blazer
1998s don't require aligning. They should be install and screw in.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-03-2005, 12:43 PM
No, every headlight needs aligning. I've seen 98+'s driving around with one headlight pointed to the sky. Things as simple as changing the bulbs in these could require realigning
Old 09-03-2005, 03:43 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
they need aligning, there are two alignment screws in them, one horizontal, one vertical, scomp gave good directions on how to' not sure of the size, but its a small socket that you need, youll see the cutouts, just pop the hood and they are ubove the lights
