Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 09-01-2005, 10:35 PM
BizarroJerry BizarroJerry is offline
Performance upgrades that don't lower fuel efficiency
Hi. Good gas mileage is important to me, but I'd like know if there are some ways to boost the performance of a car without harming the fuel efficiency. Does anybody have some suggestions?
Anything that gets more power, or better handling, without significantly decreasing gas mileage.
Thanks.
Old 09-01-2005, 11:03 PM
ec437's Avatar
ec437 ec437 is offline
Re: Performance upgrades that don't lower fuel efficiency
2 words.
Weight reduction.
Faster acceleration and braking, better handling, and better gas mileage.
SoStAsSaId: and the flight attendant is cute... if i was a lesbian, i'd join the mile high club
<---call this number
Old 09-01-2005, 11:13 PM
Re: Re: Performance upgrades that don't lower fuel efficiency
Originally Posted by ec437
2 words.
Weight reduction.
That sounds great. What are some of the best ways to reduce weight? What would you suggest for say, a 1994 Honda Civic?
Old 09-01-2005, 11:25 PM
Andydg Andydg is offline
Take out things you don't need. Spare tire, jack, rear seats, carpet, AC, radio, speakers, lighter rims, etc.
Old 09-01-2005, 11:43 PM
ec437's Avatar
Yep. Rip apart your interior and look for any sound deadening material. Get rid of it.
Old 09-02-2005, 07:25 AM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
also in terms of the engine, there's intake, echaust, all their components so, cold air intke, heads (or port and polish your current ones), valves, headers, nigh flow cat (or no cat but i think the environment's screwed up enough as it is), cat back system, port and polish exhaust side of heads. all this will get you beter fuel efficiency if you don't floor it and drive with gas mileage in mind, in other words, accelerate slow, shift early, don't speed. shifting early is just a rule of thumb, there's a specific spot where you'll get the best efficiency but you need some graphs of some sort from the manufacturer, then you need to understand them, but for a rule of thumb, the lower your rpms the better your mileage.
Old 09-02-2005, 08:36 AM
Reed Reed is offline
Send a message via AIM to Reed
i assume you dont mean handling by "performance" but if I wanted to make a car like a civic more fun to drive without hurting gass mileage i would install:
lighter/stronger clutch
lighter flywheel
16 or 15 inch wheels but kinda wide maybe 7 or 8 inches and make usre they are light (starting to see a patter?)
suspension parts, all of them, bushings, sways, springs, shocks, anything to stiffen the ride while maintaining good geometry
take off everything you dont need, seats, carpet, plastic, lighter exhaust
in case you were wondering,the pattern is LIGHTWEIGHT
Cars are like music.
If it ain't fast it ain't shit.
Old 09-02-2005, 09:53 AM
ec437's Avatar
The best way to drive for fuel effeciency is to accelerate at 80% throttle, staying in the highest gear possible, and when you get up to speed, mantain it. When do you have to slow down, engine brake with the lower gears.
Old 09-02-2005, 09:57 AM
Igovert500's Avatar
blue + red light magnet
Yeah, anything related to opening up your intake and exhaust (letting your engine breathe better) will result in more hp, and better gas mileage if you don't race it around .
As far as weight reduction, yes it's free to rip stuff out, but it also reduces ride quality if your car is a daily driver. My suggestion is to replace some parts with lightweight aftermarket parts. For instance, a carbon fiber hood can weigh 30-50lbs lighter than a stock steel hood.
Also, if you want to get more power and shave weight, focus on rotational mass. Anything that the engine must spin, that you can lighten up, will reduce rotational mass, causing you to both lose weight AND free up lost hp used to spin the extra weight. For instance, a carbon fiber or aluminum driveshaft, lightweight rims, lightweight flywheel. All of these can help in both departments.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 09-02-2005, 07:47 PM
a turbocharger will decrease gas mileage but if you don't use it it won't be by much. that's the great thing about turbos they only work when you want them to. the decrease in gas mileage is from the backpressure from the turbine.
Old 09-03-2005, 09:47 AM
jveik jveik is offline
i thought turbos had better mileage in that they make up for the lost back pressure in the way they compress the intake air. the main thing for mileage is to be the most efficient engine possible. a lot of energy from the fuel burning is lost through heat and friction. too bad we havent come up with a way to use heat as propulsion lol.
also, i would do the early shifting thing although dont drop the rpms too low or you will mess up the engine because it is harder on an engine to be revving low and pushing hard than it is to be revving higher and not having to push as hard.
its the same concept as on a bicycle, you dont go riding around in as low a gear as possible or youll mess up your knees and it is a lot harder to keep your speed up. a higher rate of pedaling is easier on your knees, and it is exactly the same concept with cars.
also, i heard that using the lowest octane you can without pinging is the best fuel for mileage purposes...
Old 09-03-2005, 10:28 AM
that is true, although it's not significant. turbochargers make more power but they reduce fuel economy because it only really makes boost when you floor it, so if you're driving for fuel economy, the turbo on't be making much power if any. there's a thread in the fuel economy section of the light trucks forum that talks about acetone helping fuel economy, check it out.
Old 09-03-2005, 10:07 PM
so would a supercharger be better for mileage purposes since it is belt driven and wont rely on high exhaust flow?
Old 09-03-2005, 10:38 PM
sracing's Avatar
sracing sracing is offline
Nope. Same deal. The belt driven charger puts a load on the engine to turn the impellers. This is lost energy. No free lunches.
Jim
SR Racing Inc.
Old 09-04-2005, 07:01 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
simple, never offer a ride, rip out all seats bar the drivers one less people-weight less fuel consumption
Seatbelts Saved My Life
Closed Thread
