Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 09-01-2005, 08:55 PM
willy_g77 willy_g77 is offline
tranny conversion, auto to 5spd
hello, i have a huge problem, my is a 1993 nissan sentra se-r, and it wont shift and it will hit the rev limiter, im tired of letting off to let it shift. i wish it was a 5spd. i can't find a auto tranny to switch out with mine, but i found a 5spd out of an se-r and the guy said i can have every thing for the tranny for $300.. what is all involved in this process?
would i have to switch computers? basically i need a parts list, so when i get ready to yank this stuff out,i'll have everything. im a decent mechanic, and i have two other decent mechanics helping.. yes senoirs in high school, but still.. we've built a rat rod from the ground up.. and is it possible to get this done in a weekend?
Old 09-01-2005, 11:43 PM
nissanstreetz nissanstreetz is offline
Send a message via AIM to nissanstreetz
Re: tranny conversion, auto to 5spd
alright well let me tell you my advice to you would be to get a cheap car thats the same make as yours cheap and just take the parts off of that car I think that would be your best bet but I'm looking up some shit for you you'r lucky I'm bored lol
Old 09-01-2005, 11:48 PM
alright well here is what you need not everything but some
tranny, ecu, driveshaft, master & slave cylinder, lines, clutch kit, flywheel, 3rd pedal, shifter,
as for the ECU you don't neccesarily have to remove it but I know it makes it easier. I'm pretty sure an automatic ECU still retains things like the rev limiter and things like that but I'm not 100% sure but thats a start hopefully someone else can tell you the other stuff
Old 09-01-2005, 11:49 PM
honestly though I know its expensive the 300 dollars probably won't cover nearly any of the things you need from what I know usually people spend about 2,000 dollars to swap thats why I havn't done it.
Old 09-02-2005, 12:02 AM
alright I talked to my friend and he said the biggest problem he had was the starter is in a diffeent position in an AUtomatic in your yr sentra so that was the biggest problem he had. He emailed me all the shit he thinks you'll need here,
Parts Needed:
5spd tranny (try and get the I30 LSD or Canadian Maxima LSD if possible – doubt it)
Both Manual drive shafts (if you have ABS you need specific ones, if you don't have ABS you can use ABS ones)
1 clutch kit (clutch disc, pressure plate, throw out bearing)
2 shifting rods (support rod + control rod) (acquire used w/ all the hardware)
Return spring (connect to the 2 shifting rods (Buy this new, the stiffer the tighter your shifter feels)
1 5spd starter
1 shifter (Acquire used to get nuts and bolts (buy with the shifter rods)
1 shifter console piece (interior)
1 shift consul bracket (Replaces your auto one) (interior) (dealer name plate bolt and transaxle hole cover)
1 brake pedal
1 clutch pedal
1 master cylinder
Hydraulic lines for clutch
1 slave cylinder for clutch
1 extra set of tranny harnesses (might come w/ 5spd tranny)
1 18ga wire and wiretaps
Assorted cotter pin set.
1 Manual Fly wheel
1 Manual motor mount
Tranny Fluid (GL-4 or redline is preferable)
Locking pin and clip for the clutch pedal to the master cylinder (you could bend a nail but I would go to the dealer and pay $4)
2 nuts that fit the threads on the clutch pedal.
1 bolt that bolts in the top of the clutch pedal (the dealer can find it's size for you)
1 bolt that connects the control rod to the tranny (the dealer can find it's size for you)
1 Haynes Manual just in case you need extra help
there ya go hope that helps lol
Old 09-02-2005, 10:37 AM
Chiquae07's Avatar
Chiquae07 Chiquae07 is offline
Send a message via AIM to Chiquae07 Send a message via MSN to Chiquae07
thats a lot of stuff to buy and a lot of work, that just makes me want to straight up buy a manual, but if you got the money, go ahead.
Old 09-02-2005, 02:24 PM
holy crap!!!! thats expensive, the guy said i could take off anything i need for the swap for 300, but i would need all that other stuff.. welp screw that idea, being in high school i got low budget projects.. i wish i was one of those spoiled rich kids!!! i hate $6.50 an hour!!!! well, any one know where to look for a good auto tranny? or what auto's will work in an se-r?
