Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-01-2005, 04:07 PM
93DXon18s 93DXon18s is offline
CEL flashes 1, 2, 5, 5????????????????
i have a 95 eagle talon esi 2.0 automatic. Ive replaced the valve cover gasket and o-rings, new plugs (NGK Iridium IX) wires still look pretty new and im in the process of redoing the suspension so the car sits on 4 jack stands , also i dont have an OBD-I scanner and apparently cant find one(tried advance auto, auto zone, napa, pep boys, no one has them or there are no more left) anyways, i did what the manual said to do to check the codes by using the ignition and the CEL flashes once,pause twice pause 5 times pause then 5 times and thats it. for the life of me i cannot find out what this code is or if its multiple codes or what. please help
Old 09-02-2005, 07:14 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: CEL flashes 1, 2, 5, 5????????????????
If I remember correctly you should have 2 codes there. 12 is your CEL and 55 is letting you know "end of codes".
Search around, I know I have seen the individual codes posted on here before.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
