Performance help
Anyone know of the cheapest way to get a good 30-40 hp out of a 97 toyota camry(4cyl 2.2L 5SFE engine)? I know it sounds kinda funny but thats the car i own right now and was wondering what type of parts i'd need. What do you guys suggest for someone on a budget?
You're not going to get 30bhp N/A without rebuilding the engine to some degree. It's that simple. Anyone that tells you otherwise doesn't have a clue, or is lieing out the yang. Don't trust them farther than you can throw spark plugs at them!
![]() Maybe find the last of the Bosal headers, port & polish the heads, install a piggyback. That'd get some power. In order on what I would personally do: Turbo it 50 wet shot - n2o Buy the Ripp S/C kit Buy the weak turbo kit. If you don't use it much I'd do the n2o before the turbo. The 3s-gte heads swap, the 3s-gte exhaust manifold swaps (Regardless of the heads). That means you can turbo a 3s-fe/5s-fe fairly easily. 3s-gte exhaust manifold CT-26 turbo (or drill out an adapter plate for whatever) intercooler piping Save $50 misc things people never remember - T bar clamps (hose clamps can slip over time, but you can normally get away with using them if you're not over-doing it) & connectors. Downpipe to connect to the stock exhaust. Most of the cost goes to fuel upgrades. 190lph Walbro 330-390cc injectors (Depending on what you want to try to run) or add 650-720cc worth of fuel from extra injector<s> Some piggyback to tune the AFM to run the new fuel injectors - safc, smt, e-manage, ftc1 unichip etc. That's about it. Only thing to note is that you're pretty well confined to life under 230bhp on the 5s-fe, and 200bhp on a 3s-fe. Power wise they're not over-built like most Toyota engines - They can't double stock power. :'( )
Toysrme257th - AIM about anything, anytime; including v6 turbos. World's second ES 300/3vz-fe Turbo. |
