Old 09-01-2005, 01:50 PM
joema joema is offline
Is rear hub/abs sensor asbly on '97 serviceable?
Dealer just told me that my abs problems were being caused by a bad rear hub/abs sensor assembly. The part is over $500 ! Is it serviceable? On my Chevy truck, the sensor can be cleaned or replaced seperately. If its that much $$$. I may just pull the ABS fuse.
Old 09-01-2005, 02:50 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Is rear hub/abs sensor asbly on '97 serviceable?
Its serviceable in respect that you have to swap out the whole hub-bearing assembly. The wheel sensor is not serviceable separately. I've seen the rear hub for the GP from $250 and less at national auto parts stores. Even lower at a salvage yard.
Here's a helpful old link:
http://www.automotiveforums.com/vbul...light=rear+hub
BTW - Do not get a Valuecraft brand. Good luck!
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
AF Community Guidelines
Old 09-02-2005, 07:50 AM
Thanks ! So, the sensor part of the assembly can't even be cleaned?
Old 09-02-2005, 11:43 AM
BNaylor's Avatar
The best you'll probably able to do is clean the electrical contacts on the jack and plug sides. Plus check the wiring leading up to the ABS/Wheel sensor and make sure the electrical connector is making good contact. Good luck!
Timeslip 08/12/06
Old 09-02-2005, 02:52 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I can sell you an AC Delco hub for $151.00 plus S/H. Avoid the imported cheapo's on the hubs with ABS sensors on them, unless you want to do the job again soon.
