Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 09-01-2005, 11:38 AM
cobiaac cobiaac is offline
Unhappy 97 tbird not charging
system is not charging have new batt. and alt. son hooked up batt. backwards. you can charge batt. car will run for a short time then die.
Old 09-01-2005, 07:29 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: 97 tbird not charging
Take the alternator back and have them test it. They may give you a new alternator. Just don't tell them the battery was connected backwards!
Old 09-01-2005, 08:32 PM
coondawg6 coondawg6 is offline
check on the side of power distribution center under the hood (where all the fuses are) theres a 100 amp fuse bolted to the side probably blew when hooked up backwards
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
Old 09-03-2005, 02:12 PM
97Bird's Avatar
If you find the 175A fuse is blown I would still have the alternator tested since a few diodes or regulator are probably toast, also.
