Can anybody give me step by step instructions to adjust Throttle Valve Cable. Grand Cherokee Laredo 4.0 liter Multi port injection with selectrac transmission. Also how do you adjust Gas pedal cable.
Thanks Spenser |
Re: Adjusting TV Cable
Throttle Valve Cable Adjustment Procedure
(1) Turn ignition switch to OFF position. (2) Remove air cleaner if necessary. (3) Disconnect cable end from attachment stud. Carefully slide cable off stud. Do not pry or pull cable off. (4) Verify that transmission throttle lever is in fully closed position. Then be sure lever on throttle body is at curb idle position. (5) Insert a small screwdriver under edge of retaining clip and remove retaining clip. (6) Center cable end on attachment stud to within 1 mm (0.039 in.). (7) Install retaining clip onto cable housing. (8) Check cable adjustment. Verify transmission throttle lever and lever on throttle body move simultaneously. |
Thanks for info on cable adjustment.
Can you tell me where the Transmission computer control module is located? |
what year and what model tranny do you have?
The above TV adjustment is for the 97 42/44RE. if you give me the year of your jeep, i can give you exact TV cable adjustment depending upon your exact transmission.
How about for a 1994 grand with the 5.2V8?
Thanks |
that would be the 46RH...
Here is a quick summary of the TV cable of for your tranny.. 1. Disconnect the TV from the throttle lever. 2. Make sure the TV cable is end and stud is aligned (or centered on one another) to within 1/32" in either direction. - if it is not centered the the cable will need adjusted. - to adjust it: There is a button on the end of the cable housing, where it clamps onto the throttle accessory bracket. push the button down and push or pull on the cable to bring the cable within spec, then reconnect the cable to the cable stud on the throttle lever. 4. Now with the help of an assistant you must check the movement on the throttle elver on the tranmission and the throttle body. - If both levers more simultaneously from idle- to half throttle - back to idle again, adjustment is correct. If tranmission lever moves ahead or lags behind the throttle lever, then cable must be adjuster/readjusted. for more detailed prcedure email me. Joe [email protected] |
