Hi,
My 98 honda civic stopped working recently and I can't seem to find the problem. After a day of non use I started it and it stopped in five seconds. After that it doesn't start anymore. My engine is turning when I turn on the key, but it stops when I let go. I have changed the spark plugs, wires, distributor cap, distributor rotor, starting coil and I seem to get sparks in each wire. I've also replaced the fuel filter and MAP sensor. I can hear the fuel pump turning at the gas tank when the ignition is on and the timing belt along with all other drive belts seem ok. It only has 68k and I think that I still have 20k of life in my timing belt. I'm a little stumped right now and any help would be appreciated. Does anyone have any suggestions on what I can try next? Thank You |
Re: Looking for Advice !!!
this may seem realy simple but check the battery aswell. i might only give a little juice out.
it should still have 200,000 miles of life left in it
so you are asking me what should you make? Ummmmm.... well i vote meth lab.....helps out the community and gives people like you a job I love out driving people. "what's all those cylinders for anyway"
