Old 09-01-2005, 01:53 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Question Belt Squeal when A/C on
What causes the belt to squeal when I turn on my A/C?? I just replaced the alternator belt, does the A/C run off of that one or the other one? When I replaced it and tightened the tensioner I didn't know how tight to make it so I just kind of guessed from experience w/ other belts...just in case the tension has anything to do with the squeal. Thanks ahead of time for any help!
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 09-01-2005, 09:25 AM
sLADe781 sLADe781 is offline
Re: Belt Squeal when A/C on
I can't remember if the AC belt and the alternator belt are the same but when my car used to sqeak when I had the AC on, I changed the belt and it stopped. If it's different then try changing that.
Old 09-01-2005, 10:41 AM
2old 2old is offline
If the belt is new (and you are sure you changed the right belt) then the tensioner is either too tight or too loose...
Yes, too tight a tensioner will make it squeal as well because then there is too much resistance against the belt and it's being squeezed into the V...
Old 09-01-2005, 10:46 AM
Does it matter that it's not a V-belt? It's the ribbed one, not the V one, that I changed. Anyone know which one the A/C is driven off of?
Old 09-01-2005, 01:48 PM
Law_3KGT Law_3KGT is offline
I have the same problem and i had a guy look at it and he said that the bearing was old and i needed to replace the pully or something along those lines. so yeah i don't know how correct that is but i'd like to get it fixed so any info will help me too.
Old 09-01-2005, 03:06 PM
Go to:
http://www.automotiveforums.com/vbul...squeaking+belt
Linebckr49 posted a good picture of the belts and on it it has how tight the belts should be.
