Old 09-01-2005, 12:57 AM
chatalex71 chatalex71 is offline
blazer egr question
Okay I went out and bought a obII scanner today and got code1406 differential presure feedback EGR (DPFE) sensor downstream hose off or pluged/ my engin is a V6 vorteck i dont know how many lieters right know the EGR valve was stuck sollid. claned some of that it moved again i was wondering if this could be a hard start problem it passed enisions about 1month ago but check engin light has been on since we bought the car we were told it was a chemical run through the engin and thier shop was closed to reset the computer (lying basterds). well anyways I was also wondering the best soulution to clean the map dont need a dead car in the garage I am only 16 so no mony for parts realy would like this to be a simple wekend project and dont wory I have the tools and knowlage. 1996 model Iknow you probaly have answered this abou 500 times this week but I have a tight schedual and no time to search so please for give me.
Old 09-01-2005, 10:43 AM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: blazer egr question
Ok why do you have two threads on the same thing?
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
Old 09-01-2005, 01:08 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Remove clean and reinstall your EGR valve with a new EGR gasket.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-01-2005, 09:21 PM
I have no clue why there is two threads. Sorry as it says im a newbiee. I just made one but whet shoild I clean it whith.
Old 09-01-2005, 09:28 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: Re: blazer egr question
We will let it slide this time!!!! Just kidding buddy. Use throttle body cleaner on the egr, soak it for some time if possible, a little aggitation and you should be able to get it as good as new. Good luck to you!
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 09-02-2005, 07:37 PM
BlazerLT's Avatar
AF -Advisor
Take an old toothbrush and TB cleaner and spray inside the holes to clean it and scrub it. Also check the holes in the block for any carbon buildup.
Then reinstall with a new EGR gasket and you will be good to go.
Remember to reset the computer as well.
Old 09-02-2005, 10:36 PM
where do I find Throtle Body Cleaber. (Looked at walyworld)
Old 09-04-2005, 01:26 AM
BlazerLT's Avatar
AF -Advisor
Go to any automotive store, it will be there.
Old 09-04-2005, 06:25 PM
I have to say thanks I just ysed the air compressor and cleand all whith low pressure reset the computer and it is like driving a different car. but I have a new question can a bad fule filter cause mising/ thene again the car rewly doesent get driven needs to be registered. thanks alot everyone
Old 09-04-2005, 08:11 PM
BlazerLT's Avatar
AF -Advisor
Do a tuneup:
Fuel filter
Spark plugs AC Delco only
Cap & Rotor
Air Filter
PCV Valve
Transission flush and refill and a new filter
Differential fluid and transfer case fluid change
Old 09-15-2005, 01:05 PM
cubanlorenzo cubanlorenzo is offline
Send a message via AIM to cubanlorenzo
correct me if i am wrong because i am not a mechanic. but i remember reading somewhere that if your car keep throwing the p1406 code, that you may need to buy a new egr valve. now if you have a piece of carbon jammed in there inableing the pintle to move, then i know you just need to clean it. but if you keep receiving the code with no carbon stuck in there, the article said due to normal wear, the pintle will get stuck on its own because of age and will need replacing.. i will try to find the article again.
Old 09-15-2005, 01:06 PM
http://www.obdiicsu.com/Studies/2001...StickyEGR.html
found it, it is under the section called "What's the Fix"
Old 09-15-2005, 04:29 PM
BlazerLT's Avatar
AF -Advisor
Nice
Old 09-15-2005, 05:31 PM
when i first bought my blazer like a year and a half ago, i kept getting tht code, p1406, so i just bought a new egr valve, since then i havent had that code come back so i guess mine was doing what that article was saying. hope this helps people out
Old 09-15-2005, 08:49 PM
BlazerLT's Avatar
AF -Advisor
You probably could have just cleaned it.
