Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-31-2005, 11:24 PM
Rinkler Rinkler is offline
Trouble with turbo at high boost
I have a 97 GS-T and I started having problems with my turbocharger, i think. At around 3/4 boost (stock turbo) i loose power quickly and the car bogs badly... I'm thinking the turbo might be going and it cant spin that quickly anymore. Do i need a new turbo or is there anything I can do? I searched for some insight but I couldnt find anything
Old 09-02-2005, 03:17 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
sounds like old plugs and wires. replace those first if you haven't lately
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 09-03-2005, 03:57 PM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
There are so many things it could be before your turbo...
Things to check...
Plugs(corroded? fouled?)
Plug wires(Start up the car in a very dark place and watch for sparks)
Plug gap (.28-.32)
Coil pack(Mine was bad when I bought my car)
Boost leak(Many different ways to make a tester, check vfaq.com)
exhaust leak before the turbo(Crack in headers, missing studs, etc)
Fuel pump(If you have to replace this, just upgrade)
fuel filter(Comes with upgrade)
87 octane(If you're running this octane, that may be your answer)
If you have any questions about how to check any of these things you can PM me. Good luck!
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
