Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 08-31-2005, 10:46 PM
Jim Rockford Jim Rockford is offline
92 Eighty Eight little to no brakes
On my brother's 92 a few weeks back his front brakes were grinding the pedal got very mushy, I repaced the front pads and began beeding them but i got no pressure from the driver side caliper, I figured it was a bad caliper so i went out and got a new one and installed it and same problem. Someone told me it may be the ABS module or something along that line but i still am at a loss. Anyone know what could be causeing this? Thanks.
Old 09-01-2005, 09:58 AM
atv087 atv087 is offline
Send a message via AIM to atv087 Send a message via Yahoo to atv087
Re: 92 Eighty Eight little to no brakes
maybe a cut in the brake line? or the master cylinder
Old 09-02-2005, 07:03 PM
tri-power's Avatar
tri-power tri-power is offline
Did you run the master cylinder dry when bleeding?
Old 09-04-2005, 11:00 AM
auto trainy auto trainy is offline
what Tri-Power is asking is very important,you may have worsened the problem you now have.
Old 09-06-2005, 03:27 PM
tri-power's Avatar
The reason why I asked that is bccause each brake line feeds directly into the master cylinder on that car. So if you ran the master cylinder dry, you will have to bleed all of the other lines also.
