Old 08-31-2005, 09:28 PM
Killa's Avatar
Killa Killa is offline
Unhappy help my steering wheel is moving left and right
steering wheel move left and right ( not that much , just moving left 1 second then right 1 second ) , what I need to do now ?
Old 08-31-2005, 09:52 PM
Killa's Avatar
oh by the way , I got 97 gs 5 speed.
Old 08-31-2005, 09:59 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Re: help my steering wheel is moving left and right
I would say you need an alignment. This is often a tell tale sign for when your car needs an alignment. Except ussually the steering wheel will tend to turn to one side and you car will pull to one side. I have never heard of a car turning left then right or vis versa. But in my opinion it sounds like an alignment problem. When was the last time you had an alignment done? How old are your tires?
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 08-31-2005, 10:06 PM
Killa's Avatar
I bough the car 3 year ago ? I never alignment the car before ( yes it If I take my hand off the steering wheel while the car is running , it will slowly move to the left , ( how much for alignment ? ) thanks.
Old 08-31-2005, 10:10 PM
macder macder is offline
Send a message via MSN to macder
What you've described is a typical sympthom of unbalanced tires on the front axle. My best guess is that your tires are wearing unevenly (unaligned, worn tie rods, ball joints, etc...). Uneven tire wear will screw up your balance for obvious reasons.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 08-31-2005, 10:15 PM
Killa's Avatar
so how do I fix that ?
Old 09-01-2005, 09:14 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Take it to a dealer.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 09-01-2005, 04:20 PM
The dealer would be the last place I'd take any car to unless under warranty. Take your car to a shop/mechanic you trust, get them to inspect all components of your front suspension, and steering. Replace anything that is worn, buy new tires, balance them, and finally do an allignment.
-Stage 2 Crane cams
-Custom header
-Bored 0.5mm
Old 09-01-2005, 04:44 PM
SpyderGuy97's Avatar
SpyderGuy97 SpyderGuy97 is offline
Send a message via AIM to SpyderGuy97
Re: Re: help my steering wheel is moving left and right
good call
Zack
Old 09-01-2005, 04:50 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Killer7 you write like a 12 year old, clean up the grammar a bit man.
Spyderguy your pic is freakin huge, i about had a heart attack when i scrolled down and saw that thing. Make the pic a little smaller man...
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 09-01-2005, 10:06 PM
NateS's Avatar
An alignment would cost you between 60 and 90 bucks. But sounds like you need some more work than just an alignment.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 09-01-2005, 11:54 PM
I know so many people that do exactly this, and end up getting screwed over. One of them even had their tires switched out, and replaced with 4 completely different tires. They didn't notice for 2 weeks until I pointed it out to them. And how are you gonna know they actually did the work? It's pretty easy to say you did this and that, when the person knows nothing about what you did. I don't think there is an honest shop left in Wisconsin, because they know most people that come to them are too stupid to actually check up on what they did to the car. Yeah the dealer will charge you up the ass, but atleast I know the shit gets done, and done right for the most part. I don't have to worry about jacking the car up and looking for new parts.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 09-02-2005, 10:19 AM
Killa's Avatar
my mitsubishi dealer is 2 hours away from me
