Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 08-31-2005, 09:11 PM
Waterfordjim Waterfordjim is offline
Angry Location of fuel pump relay on 95 Tbird
.....Could someone please tell me the location of the fuel pump relay on a '95 Tbird with the 3.8 V6??? I cant find it..... It has a intermittent no start and fuel pump replacement did not solve the problem.....
Yeaaaaaaaa!
Old 08-31-2005, 11:41 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
Re: Location of fuel pump relay on 95 Tbird
Should be in the engine compartment right behind the right headlamp.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
Old 09-05-2005, 03:18 PM
Unhappy
????????? I tore the car apart behind the right headlight..... no sign of the fuel pump relay!!!!!!!! I removed the airbox and looked everywhere behind the headlight..... This is a 1995 3.8 non supercharged car with a distributer, etc..... any other ideas?????? any help would be much appreciated...........
Yeaaaaaaaa!
Old 09-05-2005, 03:48 PM
97Bird's Avatar
97Bird 97Bird is offline
As flewthecoupe said it should be in back of the right headlight (pass. side) and in front of the airbox. It is in a module called the Constant Control Relay Module (CCRM) and should have about 21 wires going into the 2 row 24 pin connector. I think the connector is held in place by a screw in the center of it. I have a '95 with a 4.6 but I would think the 3.8 should be similar.
Old 09-05-2005, 04:23 PM
Okay, I know what module that you are talking about. Do you mean that the pump relay is inside of that module with all the wires going to it?????
Yeaaaaaaaa!
Old 09-07-2005, 10:57 AM
97Bird's Avatar
Yes, I do and it is!
Old 09-10-2005, 02:26 PM
Unhappy
???????? I tore into that module, and I find THREE relays that are all identical, and they are soldered into a board........ Any one know which relay it is???????? this does not appear to be a serviceable item....
Yeaaaaaaaa!
Old 09-10-2005, 05:45 PM
97Bird's Avatar
I would think you would have to buy the whole module. You need a wiring diagram for your year Bird to find the color code and location of the wires for the fuel pump relay. For a '97 the connector has three terminal locations that aren't used. The one on the side by itself is terminal #9 and the two on the other side are at #19 and 20. Knowing these locations you can decifer terminal #'s for the rest of the connector. Terminal #5 (PK/BK) is fuel pump output, #11 (BK/Y) is pwr going through relay to #5 and #18 (LB/O) is the fuel pump relay control. The PCM Pwr Relay that is connected to terminals 8,10,12,13,16 and 24 is what supplies power to energize the fuel pump relay coil so that may be the bad relay.
