Go Back   Automotive Forums Car Chat > Ford > Galaxy
Old 08-31-2005, 07:59 PM
bradon bradon is offline
Exclamation motor
how can i make the motor quit shaking help
Old 09-01-2005, 08:12 PM
stang351 stang351 is offline
Re: motor
well its natural for any motor to move some...especially an FE block which i guess is what you have since its in the Galaxie section, maybe a 6cyl, but it'll move some too they're just old motors.
If your motor is moving a lot, check to make sure your motor mounts are still good. If that's not the problem just check all the nuts and bolts in your engine, your headers will come loose every once in a while
My '86 Mustang ...and my '63 Galaxie Resto Project
Old 09-01-2005, 08:14 PM
Re: motor
..also next post specify your problem with what motor you have, what kind of rattle/shake it is, etc...
Old 09-01-2005, 08:35 PM
Unhappy motor
it is a 390 and the motor is makeing the car shake back and forth when it is idleing.
Old 09-02-2005, 10:20 PM
Yes it sounds like you got a broken motor mount...
of course you might just have a big ol' cam , but seriously it sounds like a motor mount so i'd check them but i'd get it lifted at a shop it's too much of a risk to get under a 3900 pound car with just a jackstand on a 40 year old car even though i prefer to be a shadetree mechanic i wouldn't do that
Old 09-03-2005, 09:32 PM
M3FordBoy's Avatar
M3FordBoy M3FordBoy is offline
Re: motor
^I wish someone would have told me that one arm ago. J/K Ya I never get under my car without the jackstands sicurley in place at least.
'91 Kawasaki Ninja 600R
Newest Toy: V&H, Stage 1 carbs
'89 Honda Accord DX
A20a1 5spd Daily Driver
'68 Ford Galaxie 500 XL
390fe C6 First Car/Project Car
See/hear the ride.
http://www.youtube.com/watch?v=rO0C-qxj6qA
Old 11-08-2008, 06:52 PM
BoogiesAdda BoogiesAdda is offline
Re: motor
Cars do not have motors they have engines a motor runs on electrical current and an engine runs on combustion
Old 11-10-2008, 08:48 AM
MrPbody MrPbody is offline
AF -Advisor
Re: motor
In the vernacular, "motor" is quite popular. You're correct, though. A "motor" converts electrical energy to motion through magnetics. An "engine" converts heat energy to motion. But Ford calls their performance branch "Motorsports" so it MUST be okay... (:-
As for the shaking, assuming all the general tune-up parts (cap, rotor, wires, plugs, etc.) have been checked, I would look at the valves. Older FEs are notorious for burning exhaust valves. They WILL shake as describeed when that happens. Do a compression test, "dry" first, "wet" second. I suspect you'll find at least one cylinder with zero or close to it.
Jim
Jim
Old 11-13-2008, 05:54 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: motor
Boogies,
Please do not resurrect ancient threads. They are kept for reference only; usually its pointless to answer them because the issue at hand has usually resolved itself. It's best to start a new thread if you wish to re-start an old discussion on a subject.
Furthermore, regular AF users find resurrected ancient threads to be annoying.
For example, MrPbody has just used his valuable time and vast, encyclopedic knowledge of all things automotive to answer a question that is more than three years old!!
Trust me, he will be pissed when he finds out.
Run while you still can.
Old 12-01-2008, 09:10 PM
cactus*garage cactus*garage is offline
Re: motor
any mecanic out there i need some advise on 302 engine
Old 12-04-2008, 03:20 PM
MagicRat's Avatar
Re: motor
Welcome to AF.
Well, most of us think we are mechanics. What is the problem you are having?
BTW, for best results, start a new thread in this section for your question.
